a dumb question about rims
Old Sep 22, 2006 | 09:00 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
Transmission: stock BW 5 spd.
Axle/Gears: stock 3.42
i know this probably sounds dumb but... can you sandblast aluminum rims?
Old Sep 22, 2006 | 09:56 PM
chevy boi's Avatar
Car: 1989 i roc-z28
Engine: 350 tpi l98
i did and i didnt have any problems, but i ended up with a rougher surface then i thought i whould get, I whouldnt do it unless you are just getting rid of the old paint and planing on polishing or painting them
Old Sep 26, 2006 | 12:51 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
I'd look at a softer blasting media other than sand..
You can get plastic beads and even crushed walnut shells made for the job. They are hard enough to wear away the paint, but not hard enough to scratch aluminum.
Walnut Shell Blasting, Walnut Shell Blasting Media, Walnut Shell Blasting Media Online, Walnut Shell Grit, Walnut Shell Blasting Equipment
Plastic Bead Blasting - Eagle Auto Stripping
Old Sep 28, 2006 | 12:45 AM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
i have a set of 'turbo-cast' rims, which media would you recomend?, where could i get it? & how much would it cost?.....
the guy who has the sandblaster says it will make the rims rust, is this true?
Old Sep 28, 2006 | 08:12 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
Aluminum doesn't rust...it can oxidize, but it won't rust. I had my aluminum rims sandblasted, and while it is a little rough afterwards, it can be sanded down. From my own experience, I wouldn't have them sandblasted mostly due to the fact that it is more time consuming to finish them afterwards. I didn't know any better and I got them done for free so that is why I got mine sandblasted. If you are planning to polish them, as I was, use glass beads, walnut shells, or even baking soda. Any shop that does sandblasting should be able to provide any of the media listed, if not, find someplace that does.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
