Functionality of Hood Vents 82 Z28
Old Jan 12, 2007 | 03:58 PM
Chevyz2882's Avatar
Car: 1982 Z28
Transmission: 700-R4
My camaro has the hood vents that open up, when I bought my car is had been switched from the cross fire injection to carbed, so I never figured out how these vents worked, but what was the purpose of the hood vents? Did they open for any reason or were they just for show?
Old Jan 12, 2007 | 06:14 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
They would open during acceleration and provide a direct air flow into the CFI intake. It was a rough way of having direct air intake.
Old Jan 13, 2007 | 01:45 AM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
yea I have them on my 83 crossfire. I am currently taking a vacuum motor and hooking it to the vents so I can get the affects of the induction system on my carb conversion.
Old Jan 18, 2007 | 07:50 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
If the air door assembly is complete,including the door solenoid,you could activate the solenoid using a micro-switch on the throttle linkage.This would be similar to a NO2 setup.My '83 still has a very nicely funtioning CFI setup,one that hasn't been tinkered with,and the air doors are neat touch.And you do get outside air into the air cleaner,as to any ram effect I'm not sure of,but you have to deal with water intrusion.
Hotrodboba400
Dec 10, 2019 07:07 PM
TBRays98
Sep 6, 2015 05:05 PM
Ian Irvine
Sep 4, 2015 08:08 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
