Please help me identify this car!!
Old Sep 13, 2006 | 01:27 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
My dad is looking at buying this car. It is an 82 w/ LG4 ... 4-speed ... 86K on the clock.
The 5th spot in the VIN is an "X", which denotes "Trans Am Special Edition".
Does this mean Recaro? 'Cause it doesn't have Recaro seats and it obviously has the wrong wheels on it. But it is an overall nice car. Oh, and the front bumper doesn't look quite right either ... but I don't know ... I'm not an expert on the early 80s T/As at all!
How much is it worth?
He already has an 86 T/A and wants to replace it with this one.
Old Sep 13, 2006 | 02:00 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
If that is an '82, then someone changed the nose and added a later style rear wing in addition to adding the GTA wheels. The seats are the "PMD" seats, popular I think among the Knight Rider crowd.
Old Sep 13, 2006 | 02:11 PM
wildjeff's Avatar
Car: 1983 Trans Am
Engine: L69 5.0L HO
Transmission: Manual
There is no Trans Am Special Edition. The Trans Am and the Firebird S/E are two different sub models of the Firebird line.
The fifth digit identifies the series.
S = Firebird Base Model
W = Firebird Trans Am
X = Firebird S/E
The Recaro option is only available on the Trans Am.
The body on the car you’re looking at is not right for 82. It’s either an 82 with an 85 or later front end or an 85 or later with 82 PMD seats.
Also, all automatics in 82 firebirds where 3-speeds not 4-speeds
What is the full VIN?
Old Sep 13, 2006 | 02:18 PM
Bull's Avatar
Engine: LT1; None
Just found the ebay listing for the car. Here is the vin that is listed:
1G2AX87HXCN532796
Old Sep 13, 2006 | 02:27 PM
gcgarner's Avatar
Right on, Bull!
Thanks for the helpful info, guys! I thought something looked weird about the front and the spoiler.
Also, the 82 S/E's did come with a 4-speed option. I never said it was automatic. Board member "82 S/E WS6" has a VERY nice S/E with 4 in the floor.
https://www.thirdgen.org/forums/memb...2-s-e-ws6.html
I'm sure this car has probably been in some trouble. But I doubt I'll even go through the trouble to run CarFax on it now ... unless anybody has unlimited CarFax and wants to do that .
But $1,400 doesn't sound like a bad deal
Old Sep 18, 2006 | 09:49 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Thats not an 85-newer nose. Thats an 82-84 Firebird/Trans Am nose with the solid grill inserts.
Old Sep 22, 2006 | 08:19 AM
PAformula's Avatar
Is the car in question in Johnstown, PA by chance? If so, I live nearby.
Old Dec 4, 2006 | 02:59 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Old Dec 5, 2006 | 09:16 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
--THe car is an S/E (Special Edition) made from 82 - 86 as the Luxury edition of the Firbird line
--The Hood is from an 85-92 Trans Am
--The Spoiler is from an 85-90 Trans Am, or a 87-90 Formula.
--The Seats are PMD, not sure if you could get those in an S/E, but I suspect you could.
--The Wheels are from an 87-92 GTA or 91-92 Trans Am.
JOhn
Old Dec 5, 2006 | 10:06 AM
wildjeff's Avatar
Car: 1983 Trans Am
Engine: L69 5.0L HO
The PMD seats where standard in the 82 S/E along with the luxury trim options, RPO B20.
Old Dec 5, 2006 | 11:19 AM
84L69TA's Avatar
Car: 4 Mopars total
Originally Posted by okfoz
--The front Facia is from an 85-90 Firebird OR a Formula
JOhn
No it isnt. The nose is from an 82-84 Firebird/Trans Am without W62 and has the solid grill inserts in place. Take a closer look.
Old Dec 5, 2006 | 12:06 PM
okfoz's Avatar
You are indeed correct, I was looking at them and at a glance it appeared to have the little bumpers on it like the later firebirds... I recant my statment.
John
Old Jan 18, 2007 | 12:21 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
Old Jan 18, 2007 | 08:28 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
NICB's VIN Assist shows:
1 Country of Origin = United States
g Manufacturer = Pont General Motors
2 Make = Pontiac
A Restraint System = Non-Passive Manual Belts
W Line = Pontiac Trans AM
87 Body Style = Coupe 2dr Plain Back Special (highlighted for attention)
H Engine = 5.0l v8 4bbl
1 Check Digit = Valid
C Year = 1982
L Assembly Plant = Van Nuys, CA
5xxxxxSequence Number = In Range
Old Jan 18, 2007 | 09:17 PM
wildjeff's Avatar
Car: 1983 Trans Am
Engine: L69 5.0L HO
Originally Posted by Fast68
it is not an s/e if its an 82 and has X in the vin
83-up with X was s/e yes, but not 82
82 was unique like this with the model code
here is my 82 T/A X-digit car vin decoded:
http://www.carfax.com/cfm/check_orde...AW87H1CL5xxxxx
good luck
Where did you get that from? Everything I have says that X was used for the S/E in 1982. I don’t see an X in your VIN 1G2AW87H1CL5xxxxx. I see a W in the 5th Spot which is for Trans AM.
X = Firebird S/E
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
