RPO Code Decoder?
Old Jan 31, 2007 | 09:31 PM
TurbomanKnight's Avatar
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
RPO Code Decoder?
I recently bought a 92 Camaro RS. I found the Service Parts Idendification Sticker. I want to decode it, where can I find the info I need?
Thanks!
Old Jan 31, 2007 | 09:40 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
There's a decoder on here that you can download or you can check out the one on Camaro Source ( http://www.camarosource.ca ).Some codes are recognized and some you'll get differing returns.Also on '92s,I believe '90 up,you can go to a GM parts deptartment and they can run your VIN thru the system and give you a print out.
Old Feb 3, 2007 | 09:09 PM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
Send me your e-mail and I can give you the whole list of RPO codes.
Old Feb 3, 2007 | 09:12 PM
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
Send them to Suprasuprise111@aol.com
Old Feb 5, 2007 | 08:31 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
You can also buy "The Camaro White Book". It lists all the codes, production numbers, colours and significant information and changes for each year(67-02. Any book store can order it for you.
Old Feb 5, 2007 | 12:36 PM
Gramps's Avatar
Car: 87 Camaro IROC
whats the cost of this "camaro white book"
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
