Manual Transmission Identification
Old Mar 8, 2007 | 12:25 PM
HuggerI-ROC's Avatar
Car: 99 Mystic Green Trans am
Engine: LS1: Heads, MS4 cam, bolt'ons
Transmission: Fully built T-56 w/Spec3 & Pro 5.0
I trying to find out what this transmission I have setting it my garage is.
It came out of my swapped RX-7 that I replaced with a T-56.
the mounting bracket used for it was for a t-5 transmission
It has a 14 input shaft and a square shifter mount not a rectangle.
The starter that was working with it has the same bolt pattern as a new GM starter like a LS1 starter bolt pattern just real big. There is an ID tag bolted on the rear/tailshaft housing on the passenger side reading
_14084169______02963 <-(very hard to read not to sure of this one)
_13-52-671_____25614
as best I can tell
I have tried to decoding help online but they only seem to go up to 81.
any other places I should look for #’s?
Did the v6 camaros come with 5-speeds with a 14 input shaft?
any help will be appreciated,
Thanks, JR
Old Mar 8, 2007 | 06:27 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
if its 5 speed then its probably a t-5
http://www.jalopyjournal.com/forum/a...p/t-83466.html
http://www.saoca.org/protected/forum...php?t-251.html
Old Mar 8, 2007 | 10:53 PM
Thanks alot man,
I followed a link to 5speeds.com from one of your links.
I relooked at the tag because there are no 1352-671.
I is 1352-071 on the tag which makes if from a 1985 camaro/firebird 2.8 V6.
now off to see if any of the V6 guys want it
Thanks again, JR
Old Mar 9, 2007 | 08:19 PM
Drew's Avatar
Good luck with that, I've got one in the garage from an 84 V6 that I can't hardly give away. One of these days I'll tear it down and recycle the aluminum.
Hotrodboba400
Dec 10, 2019 07:07 PM
angel2794
Sep 8, 2015 06:22 PM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
