rpo decode please
Old Mar 8, 2007 | 08:53 PM
cool84's Avatar
Car: 84 trans am
Transmission: built 700r4
rpo decode please
well i tried to use the rpo decoder but it wont work on my computer for some reason. so i was wondering if somebody could run these for me? is it normal to have this many? it just seems like theres tons of them!!
ok heres what i could get so far
AAA - STANDARD EQUIPMENT
AK1 - DELUXE BELT AND SHOULDER HARNESS
AM9 - SEAT, REAR, SPLIT, BACK, FOLDING
AR9 - SEAT, FRONT BUCKET, EUROPEAN STYLE, PASS DRIVER RECLINE
AU3 - LOCK CONTROL, SIDE DOOR, ELECTRIC
A01 - WINDOW, TINTED, ALL SHADED, W/S
A31 - WINDOW, POWER OPERATED, SIDE
A90 - LOCK CONTROL, REAR COMPARTMENT LID, REMOTE CONTROL ELECTRIC RELEASE
BS1 - INSULATION, ACOUSTICAL PACKAGE
BV8 - ORNAMENTATION, EXTERIOR DOOR HANDLE, LOCK CYLINDER, COLOR
B20 - ORNAMENTATION, INTERIOR, LUXURY TRIM GROUP
B34 - COVERING, FRONT FLOOR MATS CARPETED INSERT
B35 - COVERING, REAR, FLOOR MATS CARPETED INSERT
B48 - TRIM EQUIPMENT, LUGGAGE COMPARTMENT
B97 - ORNAMENTATION, EXTERIOR MOLDING, LOWER ACCENT
CC1 - ROOF HATCH, REMOVABLE PANELS, GLASS/LEXAN
CD4 - WIPER SYSTEM WINDSHIELD, PULSE
C49 - DEFOGGER, REAR WINDOW, ELECTRIC
C60 - HVAC SYSTEM, AIR CONDITIONER FRONT MANUAL CONTROLS
C95 - DOME READING LAMP
DG7 - MIRROR O/S, LH & RH, REMOTE CONTROL, ELECTRIC, PAINTED
D02 - PAINT, ENAMEL MASTER
D1U - GEAR, SPEEDO DRIVEN
D27 - COVER, REAR COMPARTMENT, TRUNK STOW
D42 - SHADE, REAR COMPARTMENT SECURITY
D53 - ORNAMENTATION, EXTERIOR HARDWARE APPLIQUE
D80 - SPOILER, REAR DECK
D85 - STRIPE, BODY SIDE LOWER ACCENT
E5Z - SPEEDOMETER ADAPTER (DELETE)
E6N - SPEEDOMETER KEY DELETE
GU5 - AXLE, REAR 3.23 RATIO
G80 - AXLE, POSI-TRACTION, LIMITED SLIP
J65 - BRAKE SYSTEM, POWER, FRONT & REAR DISK
K19 - REACTOR SYSTEM, AIR INJECTION
K34 - CRUISE CONTROL, AUTOMATIC, ELECTRONIC
K64 - ALTERNATOR, 78 AMP
LG4 - ENGINE, GAS, 8 CYL, 5.0L, 4BBL
MD8 - TRANSMISSION, AUTO 4 SPEED, 700R4
MXO - MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5 - EMISSION SYSTEM, FEDERAL, TIER 0
NB1 - EMISSION SYSTEM, CLOSED LOOP
NOD - ASSEMBLY PLANT, NORWOOD, OHIO
NP5 - LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
N33 - STEERING COLUMN, TILT TYPE
N65 - WHEEL & TIRE, SPARE, SPACE SAVER, STEEL
N78 - WHEEL, 14X6, ALUMINUM, HUB CAP, WHEEL NUTS
PB4 - LOCK CONTROL, WHEEL
QYH - TIRE ALL, 215/65R15, WHITE-LETTER
TR9 - LAMP, GROUP
T93 - TAIL & STOP LAMP, SMOKED
UA1 - HEAVY DUTY BATTERY
UP8 - STEREO RADIO INSTALLMENT PROVISIONS
UT1 - TONE GENERATOR, WARNING
UU6 - RADIO, AM/FM STEREO, SEEK/SCAN, CASSETTE, EQUALIZER, CLOCK
U21 - CLUSTER, INSTRUMENTS, OIL, COOL TEMP, VOLTS, TACHOMETER
U23 - CLUSTER, INSTRUMENTS, TRIM ODOMETER
U25 - LAMP, INTERIOR, RR COMP, COURTESY
U27 - LAMP, INTERIOR, I/P COMP, COURTESY
U29 - LAMP, INTERIOR, I/P, COURTESY
U75 - ANTENNA, POWER, RADIO
U81 - SPEAKER SYSTEM, RR, DUAL
VK3 - LICENSE PLATE, FRONT MOUNTING PACKAGE
V73 - VEHICLE STATEMENT, US/CANADA
WS4 - MODEL CONVERSION, TRANS AM
WS6 - PERFORMANCE PACKAGE, SPECIAL
WS8 - PRICED ORDER CONFIRMATION, REFERENCE SHEET
W62 - ORNAMENTATION, AERO PACKAGE
YR1 - SEAT, FRONT CUSTOM
YS1 - SEAT, REAR CUSTOM
YT1 - BUILD UP DOOR & QTR
YT9 - OPTION PACKAGE, FISHER FURNISHED PARTS
Y06 - RING GEAR, 9.50 IN, SAGINAW, (S.P.O.)
ZV1 - MANUFACTURES CERTIFICATE OF ORIGIN - VEHICLE
15L - SILVER PAINT
15U - PRIMARY COLOR, SILVER SAND METALLIC
19A - STRIPE COLOR, ACCENT, TWO TONE, MED GRAY MET/BLACK
6ZX - SPRING, COMPUTER SELECTED, FRONT, LEFTHAND
60C - TRIM COMBINATION, CLOTH, MED COGNAC
60I - SADDLE INTERIOR TRIM
609 - SEAT BELT COLOR, MED COGNAC
7ZW - SPRING, COMPUTER SELECTED, FRONT, RIGHTHAND
8NM - SPRING, COMPUTER SELECTED, REAR, LEFTHAND
84P - WHEEL COLOR GRAY
9NM - SPRING, COMPUTER SELECTED, REAR, RIGHTHAND
any help would be greatly appreciated
Old Mar 8, 2007 | 10:07 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
heres what i got, but colors may be wrong since it depends on the year, sometimes colors were changed for a given color code,
you dont have very many RPO codes actually, usually you see lots more actually, in 80s cars anyways
good luck
D1U GEAR, SPEEDO DRIVEN
D85 : STRIPE, BODY SIDE LOWER ACCENT
E6N speedometer key delete
15L (silver paint),
19A STRIPE COLOR, ACCENT, TWO TONE, MED GRAY MET/BLACK
60C : TRIM COMBINATION, CLOTH, MED COGNAC
60I - Saddle interior trim
609 SEAT BELT COLOR, MED COGNAC
84P WHEEL COLOR GRAY
Old Mar 8, 2007 | 10:28 PM
cool84's Avatar
Car: 84 trans am
well that completes my list then. i am happy to know i have the ws6 package. and the 3.23's with the posi. i guess it wasnt as base model as i thought
Old Mar 9, 2007 | 02:13 PM
cool84's Avatar
Car: 84 trans am
Y06 - RING GEAR, 9.50 IN, SAGINAW, (S.P.O.) does that mean i have the austrailan 9? thats what my friend told me but i thought they were 89 and later
Elephantismo
Feb 13, 2019 12:51 AM
AussieZ28
Sep 30, 2015 03:36 PM
F-body-fan
Sep 24, 2015 08:29 AM
iroczguy86
Sep 23, 2015 01:19 PM
64Chief
Sep 12, 2015 08:05 AM
