header bolts for hedman's
Car: 1991 Camaro Z28
Engine: 305 cid
Transmission: 5 speed
Axle/Gears: Posi/3:42
I just removed those annoying bolts as I need to replace the header gasket on driver's side, but I wanted to know if I should replace the bolts with the bolts that require the allan key. Have any of you ever used these bolts and if so, did you find it easy to access them and tigthen them?
Thanks,
Benny
Thanks,
Benny
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
allens are pretty good yeah, easier than trying to get a socket wall between the head and the primary tubes
sometimes
trick to do is hack off the end of an allen key and use a socket and extension then you will have all the room you need for the ratchet
good luck
sometimes
good luck
ambainb
Apr 25, 2016 09:21 PM
hectre13
Sep 8, 2015 03:38 PM
Dialed_In
Aug 20, 2015 01:45 PM
