complete rpo codes for 1985 camaro
Old Apr 11, 2007 | 11:20 PM
fdcapt220@yahoo's Avatar
I need a complete RPO list for the 1985 camaro, the list that I found only contains 11 codes that i have. I have 37 more that I need to identify. if the RPO code is on the sheet in my car it should be installed on the car, correct? Or do I have to go to GM to get the codes? If anyone can help it would be greatly appreciated, thanks.
Old Apr 12, 2007 | 03:27 AM
ajmclean's Avatar
Re: complete rpo codes for 1985 camaro
the attached file has many rpo codes
and this link also has many
http://www.teufert.net/camaro/1985.htm
File Type: doc
Old Apr 12, 2007 | 08:28 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Here's one more specific for the '85 that also includes the quantity built for each code and even the original option cost.
http://www.chevy-camaro.com/chevy-ca....asp?year=1985
Many sites also offer RPO decoders where you can enter the RPO's.
Regarding the sheet in my car, there should be a sticker with all the RPO's specific to your particular '85 Camaro. It is usually found inside the console between the front seats or in the rear storage compartment. That is assuming of coarse the those stickers haven't been removed by a previous owner or those locations haven't been swapped out with different parts (then the RPO stickers may not be accurate).
If they are there, it is usually quite easy to decode them and also see if they do apply to your car.
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Randomtask2
Aug 13, 2015 01:57 AM
antares57
Aug 6, 2015 07:47 AM
