RPO Codes
Old Jun 7, 2007 | 06:16 PM
blue82_z28's Avatar
Car: 1982 Camaro Z28 w/ RS groundfx
Transmission: Tranzparts 700r4
Axle/Gears: 3.23's
RPO Codes
where are the rpo codes located on an 82 camaro z28, i was told they were on the rear hatch, but no luck finding them there...
Old Jun 7, 2007 | 06:52 PM
AmorgetRS's Avatar
Re: RPO Codes
They didn't start putting the SPID sheet (that has the RPOs on it) in the cars until 84
Old Jun 7, 2007 | 06:53 PM
blue82_z28's Avatar
Axle/Gears: 3.23's
Re: RPO Codes
so is there any other way to find out what all options came with the car from the factory?
Old Jun 8, 2007 | 12:22 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: RPO Codes
You could lift the hood and look for the cowl tag mounted on the radiator cross support. But I'm having a hard time finding a decoder for it.
Anybody have any leads?
Have you had your VIN decoded yet (that's easy )?
Old Jun 8, 2007 | 01:19 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: RPO Codes
Have you checked under both the driver's and passenger's seats to see if the build sheet is there. If you look or feel under the seat and find some paper up in the springs, pull the seat out of the car ( 4 bolts, one each corner afdte you take off a trim piece) and reterive the paper. If it is a build sheet, it will list all the RPO codes, along with other information the factory used to build the car.
Search this board for build sheet to see what you may find.
Dave
Old Jun 8, 2007 | 03:53 AM
blue82_z28's Avatar
Axle/Gears: 3.23's
Re: RPO Codes
yes, i've had the vin checked, lol, was intrigued to find out it was made in cali... but i haven't looked under the seats yet, i'll do that in the morning
Old Jun 8, 2007 | 06:16 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: RPO Codes
To know if it was made in CA, look for the L in the VIN. N designates Norwood.
Old Jun 8, 2007 | 09:43 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: RPO Codes
I've had a little bit of luck decoding the radiator trim tag on my '83 Z28.It will give you the sequential part of the VIN,carline/series,body style,build date(month/week),plant,exterior color,paint type,interior color - trim option,seat style,CC1(if factory t-top car).
If you can find a build sheet in decent readable shape it will tell you so much more.But the trim tag will help a lot.
Old Jun 8, 2007 | 09:57 PM
blue82_z28's Avatar
Axle/Gears: 3.23's
Re: RPO Codes
nothing under the seats... i just wish the vin would tell me more, oh well.
Old Jun 8, 2007 | 10:07 PM
coolram62's Avatar
Engine: LU5 305 CFI
Re: RPO Codes
Get the numbers off the radiator trim tag or better take a picture of it and post it.Then we can try and decode it for you.It's a start for you as the VIN will tell you carline.body style,engine,build plant and sequential build number.
Old Jun 8, 2007 | 10:44 PM
blue82_z28's Avatar
Axle/Gears: 3.23's
Re: RPO Codes
well i tried taking pictures of it but they didn't come out so hopefully this will do if i read them right...
C 07A 1FP87 L 183939
2bC 29L 29U W
AR9 CC1
D B S 0bb91b
the b's might be 6's and the C's could be G's it's hard to make out, even with a picture
Old Jun 9, 2007 | 01:53 AM
Re: RPO Codes
2bC 29L 29U W
AR9 CC1
D B S 0bb91b
Sorry you could not find a build sheet, but from the above information
first line C = build year = 1982, same character as the 10th digit of your vin
07A = build time = July, first week
1 = Chevorlet Division
F= Fbody style
P = Sports Coupe
87 = two door hardtop
L = Van Nuys, CA plant
183939 = Plant Sequence Number = the 12th-17th characters of the VIN
second Line...
26C Interiior Trim Code = Dark Blue Cloth Seats, C= Empress Eoven Veolur Cloth (The trim level is 2). This code appeared in box 77 of the build sheet.
29 is the exterior paint color, Dark Blue, Metalic U is for the Upper ption of the car, L is for the lower portion of the car (seems to have more meaning if you have a two tone parint job, which did not see to be available on the F bodies) The paint codes appeared in box 79 of the build sheet
W stands for Water Based Paint
Third line
AR9 is the seat option, AR9 is the standard bucket seat for these cars
CC1 is the roof option code, you have TTops
Both of these codes appeared in Box 107 on the build sheet, which lists all the RPO codes for the car.
D, B, and S are plant option codes and I have no idea what they mean
0bb91b is actually 066916 and is the ???? number. This number appeared in box 10 on the build sheet.
Here is some information from the 1982 Camaro Service manual in these two attachments...
Dave
Attached Thumbnails RPO Codes-body_id_tag_2.jpg   RPO Codes-body_id_tag_1l.jpg
Old Jun 9, 2007 | 09:33 AM
blue82_z28's Avatar
Axle/Gears: 3.23's
Re: RPO Codes
thank you for the info, seems to match how the car is right now, ttops, blue paint, blue interior, the works... lol, one thing i dislike about the car is the clock in the center console. gas is terrible in that thing though, it's the 4 speed but at 70-75 miles per hour i'm idling at about 3200 to 3500 rpm
Old Jun 9, 2007 | 07:00 PM
coolram62's Avatar
Engine: LU5 305 CFI
Re: RPO Codes
As 82Crossfire provided the info on the trim tag is what the '82-'83 cars have to go on unless you find a build sheet.I haven't been able to find out what the last line of code on the trim tag represents(mine is D S 161609).
The console clock does seem odd to some(I like that my '83 has one).But you can change the console top or take the clock out and make that space a cup holder.Interesting note is all years(at least all I've seen)console tops have the clock's 3 mounting posts molded in.It wasn't a popular option and with the advent of the ETR radios with clocks it was dropped after '85.
You have a first year 3rd Gen Z28 with the 4 speed manual.That's not a common sight these days.Not having overdrive is what's killing your gas mileage on the highway.
Old Jun 9, 2007 | 10:54 PM
blue82_z28's Avatar
Axle/Gears: 3.23's
Re: RPO Codes
yea i suppose, i'm lookin for a 5 speed maybe a 6 if i can get that sweet deal lol, but just keep the 4 speed around just for the hell of it
Old Jun 10, 2007 | 01:09 AM
Re: RPO Codes
blue82_Z28
Before I bought my 82 Z28 one of the guys I worked with bought an 82 Z28 with the same colors as yours. Does the metalic still twinkle in the sunlight???
My build sheet is at this link.
https://www.thirdgen.org/forums/hist...o-z28-lu5.html
You can get a good idea of your RPO codes by looking in box 107 at the bottom of the sheet and trying to match up the accessories you have with the sheet. It will give you a good start on your car's history.
The analog clock was supposted to be deleted in the 82 if you got a radio with the digital clock. However, I think you could still order it if you wanted to.
coolram62
That number on the tag 161609 shows up in the build sheet. However on my build sheet it overwrites the name of the box (Box 10 upper left corner), or we might know what it was used for. On my tag the line is D S B 188294. Note that the 18 looks like a 10 on the build sheet.
Sure would be nice if an old factory guy or gal would come along and let us know what that line was used for and what the letters and number mean
Dave
Old Jun 10, 2007 | 11:50 AM
blue82_z28's Avatar
Axle/Gears: 3.23's
Re: RPO Codes
yup, it's still got it's twinkle, it looks sharp as ever
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
