Single or double horns!???
Old Jun 30, 2007 | 03:13 PM
1bad86's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
Ok, My '86 iroc only has one horn, of course it has the holes for two but theres only one wire for a single horn so I was wondering if dual horns were an option or should my car have another one.
Old Jun 30, 2007 | 03:37 PM
Red1992V6Rs's Avatar
Car: 1992 RS
Engine: 3.1
Re: Single or double horns!???
Dual horns was an option. I'm not sure what years it was offered. I am pretty sure the RPO is U05.
Old Jun 30, 2007 | 07:50 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
When you look back it's funny how cost cutting shows but also how you could personalize your car.RPO-U05 was the option code for dual horns for the Z28/IROC and Sport Coupe(standard Berlinetta).
You could add the second horn with a jumper wire.But ou would have to find whether the low or high note horn would be the one you need to add.
Old Jun 30, 2007 | 09:38 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Go Dixie!!!
Last edited by Iroctopless; Jun 30, 2007 at 09:40 PM. Reason: Automerged Doublepost
Old Jul 1, 2007 | 10:58 PM
1bad86's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
Thanks guys I figured out that if I would have just taken the time to look at the RPO decoder I would have found the code for that option lol. I found out that mine came factory with single horns. I thought about the jumper wire but might as well keep it stock.Thanks again, 1BAD86
Old Jul 1, 2007 | 11:30 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
I got a Q to add, My 84 T.A has dual horns but if i press the horn button lightly only one works and if i press it hard both work. Is that normal like dual contacts or is it just not getting enough power through the button when I push lightly?
Old Jul 2, 2007 | 01:50 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
The horn button on the steering wheel does not directly power the horns. It energizes the HORN RELAY which powers the horns. The relay is located in the convinence center under the driver's side dash, adjacent to the console. I would make the the connectors are tight on both horns and maybe just replace the horn relay. The relay contact could be corroded, so it does not always pass enough current.
Dave
Old Jul 2, 2007 | 05:46 PM
1bad86's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
My horn wouldn't work, turns out it was just a bad ground...
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
dusterbd
Sep 29, 2015 08:40 AM
