sweden Need some help
Old Aug 2, 2007 | 01:24 PM
Martinmartin21's Avatar
Hi im told that i have 1991 1le camaro dunno if that is true..need som help to check if the rumours are true..what shall i do =) greetings sweden
Old Aug 2, 2007 | 01:48 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: sweden Need some help
Welcome to TGOs. FYI, a search will often provide the info you require. The following site will be helpful:
http://www.camarosource.ca/php/camar....php?year=1989
JamesC
Old Aug 2, 2007 | 04:38 PM
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Check in your center console for the RPO label with all the little codes (big white label) if it matches your vin and says 1LE then you have it
Good luck my international freind
Dave
Joniz
Sep 13, 2015 01:28 AM
Scania
Nov 26, 2003 04:58 PM
the swede
Nov 26, 2002 11:25 AM
the swede
Jul 31, 2002 04:32 AM
