Tachs...
Car: 1989 iroc
Engine: 5.0
Transmission: t-5
Tachs...
ive always been curious about the different tachs that these cars came with, i have an 89 iroc and it has a 5500 redlinebut i have seen others with 5000 redlines, is there a differnece because of the 5L and the 5.7L or is it just the cam, heads etc?
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: Tachs...
In 89, you got a 5000 redline tach if you had a 305 TBI (LO3) or a 305 TPI automatic (LB9). You would get the 5500 redline tach if you had a 305 TPI (LB9) with a 5 speed or a 350 TPI (L98).
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Tachs...
The Tachometers matched the CAM that was installed on the engine.
In 85 the TPI had the 5500 RPM Redline:
in 86 the TPI got a cam change and the tachometer has a 5000 Redline: I think 87 was the same.
I know the crossfire engines, TBI and the LG4's all had a red at 5000 RPM. The HO engine might have been higher,............ Seems like all the 350's had the 5500 Reline but I coiuld be wrong.
Guest
Posts: n/a
Re: Tachs...
That tach matching cam thing above is just a fallacy. My 86 TA has the cluster it originally came with and it had the peanut cam too, and no 5000 RPM redline anywhere to be found. I think its more 'intended' than 'absolute' just like a bunch of other things GM does.
Re: Tachs...
I've got MUCH more experience with the Camaro's and I can't speak for all the firebirds out there, but I can say that I've parted out 4 V8 Birds.
1 was an 85 TA with a 6000 Redline. The style is very different than the 86 & up tachs.
The next 3 were from 86 & 87 Firebirds / TA's,...... one was an LG4 ( 86 ) and the other 2 (87's ) were TPI 305ci cars. ALL of them have 5000 Redline tachs.
I find it hard to believe that your car rolled off the assembly line with a ( brand new designed ) Tachometer that didn't match the RPM range of the best motors being offered in that year. Sorry - but I'm a pessimist ! I can't imagine why a manufacturer would EVER put a gauge into a car that did not match the specifications of the engine moving it.
My favorite ThirdGen ( for example ) was the digital Berlinetta. There were only 3 motors available in that platform and each of them uses a different cluster JUST BECAUSE OF the Tachometer. There's one for the LG4, 1 for the LC1 and one for the LB8. Chevy didn't just stick the LC1 cluster ( Tach ) into the LB8 cars,..... they made a new cluster JUST to match the tachometer to the engines RPM ratings.
madmaxPlease - I'm not picking a fight with you. I simply don't believe that ANY 86 left the factory with anything other than a 5000 redline tach.
L69norm Here's the Tach from an 84 Camaro HO car...... I can only assume that your L69 HO was in an 84 or 85 Firebird ????
Re: Tachs...
I'm almost inclined to believe it was a marketing thing to give the owner bragging rights. While the red line was at 6000, it really didn't like it and was all pretty much all done by 5500. I always thought it felt best shifting between 4500 and 5000.
Guest
Posts: n/a
Re: Tachs...
My cluster is date coded and matches the car, and the only other owner didnt touch it. Its original.
Here's some more info on 86 birds
https://www.thirdgen.org/forums/post...07-post15.html
Notice I have no KPH either.
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: Tachs...
L69Norm that idea of bragging/advertisement sounds plausible.Remember at the time the 5.0 Mustang's tach didn't have a redline.And a big reason the L69 was brought about.
And as John in RI stated the redline on my '83 LU5 Z28's tach is 5K.
Re: Tachs...
