I got a question, i'm not sure if my camaro is an RS or an IROC main reason why is because I do not have T-Top. I have a bunch of IROC and Z28 emblems my title only says 1989 chevy lol it doesn't even say camaro i'm stumped if you have any question to ask me ask away cause I really wanna know before I go buying parts.
check between the front seats in the middle compartment for the RPO codes pate
if u have option code (Z28) then it's an IROC-Z.
and make sure that the vin on the plate matches the one u have
Kevin91Z
close
- Join DateJul 1999
- LocationOrange, SoCal
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1990 Pontiac Trans Am
- Engine355 TPI siamesed runners
- TransmissionTremec T56
- Axle/Gears12-Bolt 3.73
- Liked:26 Times in 22 Posts
What engine is in it? If its TBI it could be either but if its TPI then its definitely an IROC.
Proper rpo code for 89 is B4Z not Z28. Just clarification thats all folks!
All the vins match but I can't find any RPO codesOriginally Posted by ajmclean
check between the front seats in the middle compartment for the RPO codes pateif u have option code (Z28) then it's an IROC-Z.
Quote:
I have a 350 TPI I'm sure somebody swaped it cause under my hood it says I have an automatic [which I don't]Originally Posted by Kevin91Z
What engine is in it? If its TBI it could be either but if its TPI then its definitely an IROC. Quote:
The proper code for 89 is Z28. There is no RPO B4Z in 89. All Z28s in 88-90 were IROC-Zs so no special designation is needed to seperate them.Originally Posted by VERTIGO Z28
Proper rpo code for 89 is B4Z not Z28. Just clarification thats all folks! Supreme Member
On a title for an IROC(or Z28)it will generally say just Camaro or Sport Coupe/Z28.This is because they were options on the Sport coupe and not a separate model.
As Scott suggested look for Z28 on the SPID decal in the center console.And as Ajmclean stated make sure the VIN on the SPID decal matches your car's VIN.
Also on the VIN the eighth digit will indicate what engine she had originally.If it's a E(LO3 TBI 305) she could be either a RS or IROC.If it's a F(LB9 TPI 305)or a 8(B2L/L98 TPI 350) then she's definitly an IROC.
Agree with ScottMoyer. I have a 89 Iroc and it says Z28 on the RPO list in console. Also lists in VIN as having 350. That was my conclusion on mine.
On the inside of the console do you have a sticker with a list of codes?
