Interior tear down and heater core questions
Old Nov 6, 2007 | 06:36 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
My dad called me today to say that the passenger footwell of his 82 Pace Car was full of antifreeze. He asked what the best method to get the antifreeze from the carpet was and I recommended that he pull the carpet out and hose it down. He has a few questions and I thought I'd post them here for opinions and advice.
1. Large plastic round cap with a recessed "x" on it. Looks like a phillips head screw. Does it pop off or unscew? He tried unscrewing it with a quarter and it just twists. He doesn't want to break it, so any suggestions?
2. The rear seat belt bolt...Is there a nut under the car like on the 69s or is there a welded nut that remains stationary?
3. When the puddle occurs, is it usually a hose or the core?
Thanks all
Old Nov 6, 2007 | 07:09 PM
Re: Interior tear down and heater core questions
1. Those are just plugs, they just pop out; seat belt bolts are under there.
2. Welded
3. Generally the core
Old Nov 6, 2007 | 07:39 PM
Guest
Guest
Posts: n/a
I actually washed my carpet out IN the car. The coolant likely stayed in the passenger side front footwell (might have a slight leak to the driver side), it makes a nice pond. It'll take a few cycles of clean water and fishing that out, but it works and you dont have to diassemble the entire interior of the car.
Old Nov 7, 2007 | 08:08 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I have a "Green Machine" or "Little Green" by Bissell that works wonderful, Its a little steam cleaner. (Steam used very loosly as it creates no heat). With the hand held wand he could probably suck up most everything and then use a steam cleaner solution to clean up the carpet... It should work depending on how bad it is.
Personally I would remove the trim, the RH seat and the threshold and fold back the carpet to inspect under it for any that may have gotten through, and then suck up that and put a fan on it until it was dry.
John
Old Nov 7, 2007 | 08:16 AM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
3. Usually the heater core.
I also had a bad heater hose going to the heater core and it leaked just like the core would. So be sure to check the hoses first.
I just replaced my heater core about a month ago.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Street Lethal
Aug 14, 2015 08:25 PM
