85 L69 IROC questions
Car: 89 Formula
Transmission: TH 700R4
How many were made? (I had a Camaro white book but can't find it)
Was the rear carpeting available over the wheel well plastics?
thanks
thanks
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: 85 L69 IROC questions
2,497 (out of 21,177 '85 IrocZ's built)
This is a lucky decode because 99.9% of build counts when you combine options (Iroc-Z + engine + colour + AC, etc) are impossible to ever know due to Chevrolet not keeping stats on combination build counts.
HOWEVER . . . in '85, only the IrocZ got the L69 engine. And most individual RPO build counts are available. The RPO L69 for '85 shows 2,497 ($680.00 option). And since only the IrocZ got that engine, there's your answer.
PS; not sure about the carpet question.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Personally I think what would make the car most desirable is if it was a 5 speed.
Car: 89 Formula
its a nice car I am looking at for a pal.
Blue, T-tops, 60K miles--rear window wiper--almost every single option
thanks
thanks
Car: 1985 IROC-Z
Engine: 305 H.O.
Transmission: 5 Speed
Axle/Gears: 7.5" 10 bolt, 4.10, torsen posi
Engine: 400
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
The question on the rear compartment carpet is about RPO-B48.It was optional on the SC,Z28 and IROC(standard on the Berlinetta)and came on 18,418 total in '85.Does your IROC also have the locking load floor storage(RPO-D27 also standard Berlinetta)with 9,680 ordered.If the SPID decal is still on the underside of the console door(make sure the VIN on it matches your car's VIN)it will give all the options.
mustangman65_79
Aug 11, 2015 03:17 PM
