Paint code for rims?
Old Feb 22, 2008 | 01:32 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
I have the WS6 Fromula 16" rims and I am looking for the paint code for the silver that's painted in the windows of the rim. It also matches the center cap. Any ideas as to where I could find it?
Old Feb 22, 2008 | 02:24 PM
AmorgetRS's Avatar
Re: Paint code for rims?
You'll have better luck in the History and Restoration Board, so I have moved the post there.
Old Feb 22, 2008 | 02:39 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Go to your local paint store, if you check your RPO's look for the one that has two numbers and ends with a P. IE 14P or 24P
John
Old Feb 22, 2008 | 03:32 PM
1991Formula350's Avatar
Car: 1992 Formula
Transmission: auto stock
Axle/Gears: 3:42
When I had mine refinished, they basically came the same color as a new center cap. Call bruce at Hawks third generation parts and he should be able to answer this correctly. Down here you can get a single rim polished for 135.00 and the rim is brand new again. Andrew
Old Feb 22, 2008 | 04:27 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Thanks guys,
Ok, I found a 12P in the RPOs, so is that the paint code? I thought about getting refurbished rims but all 4 have corrosion here and there. $135 is a good price, but I figured I could do the work myself. I want to keep the look as close to original as possible without having all out polished rims that look like chrome.
I started experimenting with an extra rim that I had lying around. I can sand out the corrosion and curb marks after I remove the clear coat, but that also removes the machine lines that also hold the clear coat. So I ended up sanding the whole face of the rim with 400 then 800 and finally 1500 then I buffed the whole thing with rubbing compound.
Now it looks really good without being too shiny and it really did not take all that long. It looks like a new rim without the machine lines and clear coat. However the silver paint in the windows needs some attention. If I could get the right paint that matches the center caps I could get the rims perfect.
I guess if all else fails I could take the cap down to the paint supply and see if they can match it.
Old Feb 23, 2008 | 10:13 AM
Car: 1992 Formula
Axle/Gears: 3:42
Yea, I understand, but when they get professionally finished, the rim is like factory new. It is not chrome, it is a nice smooth, silky silver look in which you only need water to rub off the dirt when finished. You kill the rim surface with all those degreasers from the stores. Andrew
Old Feb 23, 2008 | 10:16 AM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
In my GM RPO book, 12P decodes as: Wheel Color, Silver Metallic
Old Feb 23, 2008 | 01:24 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Andrew, where did you get your rims?
Old Feb 25, 2008 | 10:03 AM
okfoz's Avatar
You will spend $75 to $150 PER rim, to get a perfect set you will spend that anyways... I would try contacting some of your local bump shops or places that sell used rims & Tires
Old Feb 25, 2008 | 07:59 PM
86TARecaro's Avatar
Car: 1986 Trans AM Recaro Option
Speaking of the Formula rims - how about the 25 holes drilled in the outside of the rim inset with what appear to be 5/16 hex heads.
How are these fastened to the wheel - do they thread out? What color were they originally?
Old Feb 26, 2008 | 07:06 AM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
I think they are just pressed in. I tried taking one out of my practice rim and they don't to want to thread out so I just left it. As far as color, the rims on my car have medium silver ones and my practice rim has darker almost black anodized looking ones. It would be nice to be able to take them out and clean thim up too.
Old Feb 26, 2008 | 10:27 AM
okfoz's Avatar
The Charcoal color was correct on the 1985-1987 WS6 Trans Am and 1987 Formula Rims. Silver should be on the 1988 ~ 1992 Formula Rims. And Black on the 1991 & 1992 Cross laced (GTA) optional Formula wheel (found on all Formula 350 w/t-tops in 91-92)
John
Old Feb 26, 2008 | 10:37 AM
Car: 1992 Formula
Axle/Gears: 3:42
Lakeshorewheelandtire.com My former white '91 is on the first page of customer photos. I actually prefer them over my Firehawk R15 rims. I will soon put them on ebay seperately as I am trying to dump both the car and rims. Andrew
Old Feb 26, 2008 | 03:27 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Nice looking car! These rims are my favorite of all factory rims, that's why I want to get them looking as best I can. $135 is still a good price compared to what some people are trying to get for used ones on ebay.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
antares57
Aug 6, 2015 07:47 AM
