83 T/A differential color question
Car: 1983 Trans Am
Engine: L69 5.0L HO
Transmission: Manual
I was cleaning the differential from my 83 T/A and it’s blue. I believe it to be original; it has all the correct stampings. Is the diff painted from the factory? and if so what color is it suppose to be?
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Re: 83 T/A differential color question
That's crazy, I was always under suspision that the axles were either bare iron or sprayed black.
All 10-bolts left the factory unpainted and the 9-bolts were painted black due to transit on salt water. Nothing changed over the run of 3rd gen cars. That is unless the Dealer did some undercoating work.
Car: 1983 Trans Am
Engine: L69 5.0L HO
Ok thanks, the car was undercoated. Good for preserving it all these years, bad for me trying to remove it. I’ll just paint it black.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I know some of the pieces were painted with a marker to verify that the bolts were tight.
I suspect to possibilities for the B&W axel being painted 1) its an outsourced part, they are usually held to higher standards than in-house equipment. 2) Since they were coming from Australia, I suspect that they may have painted it for the trip across the pond.
I actually read somewhere that the 9 Bolt axel was not as strong as the 10 bolt they used it for fuel milage as it was slightly more efficient... anyone?
John
John
Car: 83 ta
I have a 83 trans am ws6 that I removed and cleaned. What little paint was left on the rear end looked to be a low gloss black.
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
I believe the 9 bolt wasn't available till '85 on the T/A and a year or so later on the Z28/IROC.The Dana 44 was used as a service replacement and was also available over the parts counter.As stated above the 10 bolt was left bare except for marks as Okfoz mentioned.Then enter the dealer which generally undercoated all new cars as a profit margin(and it does help if applied properly).The 9 bolt being painted for shipment makes sense plus being an out sourced part.
IMissMy86TA
Aug 31, 2015 08:40 PM
LT1Formula
Aug 20, 2015 09:36 PM
