Firebird VIN# question
Old May 31, 2008 | 05:25 PM
jaybird08's Avatar
I saw a 1991 Firebird Formula with a (2) in the sixth position of the vin sequence. The websight I looked the VIN up on says there sould be a (1) or an (8) in this position for Sports Coupe. A (3) for Verts. So is this a misprint? Or is this car something more? Also the last six numbers are 200424. This websight says there were only some 51,000 cars built this year. So is this #200424 or am I reading this wrong. Every other # and letter match what the web sight says. Can anyone help me understand. O-yeah, I did see a badge on the inner doorpanel that said something about the suspention.
Old May 31, 2008 | 06:05 PM
kcobb1201's Avatar
Re: Firebird VIN# question
http://www.transamworld.com/3genvins.php
says it is a coupe if it is a 2 in the 6th position
Old May 31, 2008 | 09:49 PM
jaybird08's Avatar
http://www.autoinsurancetips.com/firebird_vin.htm This is the websight were I got the info. Maybe they need to double check their info. So thats one question out of the way. Can anyone tell me, is this car the 200,424 car produced, or does the numbering system work some other way?
Old Jun 2, 2008 | 12:35 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Actually.. From 1987 & up
1 = USA
G = GM
2 = Pontiac
F = F-body Line
S = Firebird or Formula, W = Trans Am or GTA
2 = Coupe (Hatchback) 3 = Convertible
1 = Manual Belts, 3 = Airbags
T = 3.1 V6, E = LO3 305 V8, F= LB9 305 V8, 8 = L98 350 V8
X = Check Digit
H = 87, J = 88, K = 89, L = 90, M = 91, N = 92
L = Van Nuys, N = Norwood (1987 only)
2 = Pontiac
00001 = Sequence number
John
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
