so i have a little problem......
Old 07-14-2008, 10:59 AM
camaro_boy123's Avatar
Car: 1986 Camaro z28
Engine: 350 v8
alright so i have been restoring my camaro and i have taken the complete undercarriage out of the car and had it sandblasted and powercoated. Now that i have taken the motor out of the car i have decided to paint the engine bay and now i dont want to put the new undercarriage back on the car untill its been painted. so that leaves my front end on jack stands.
my options...
Get the parts needed from the scrap yard and bolt them up temp and then paint it o nthe rolling chassis or build some sort of metal temp frame to hold the car up so i can push it onto a trailor.
im wondering is there is something very easy that you guys have used? any infromation would be awesome
Douglas
Old 07-14-2008, 11:47 AM
Pyroviking's Avatar
Re: so i have a little problem......
I have absolutely no advice to offer...
but it sure would be cool to see some pics of your restoration progress
Bring on the pr0n!
Old 07-14-2008, 11:53 AM
Engine: 350 v8
i actually just got off the phone with a scrap yard. they want 150 for the whole front end so i might just do that. i am thinking of making a cardomain site and post all the pictures of have so far ( easily 400 ) from start to finish. i will keep you posted
Old 07-14-2008, 11:55 AM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Not sure if I follow you 100% but ...
Couldn't you go ahead and put the car back together and mask off the undercarriage components while you're painting the engine bay?
Old 07-14-2008, 11:59 AM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Bring on the pr0n!
+1, but the junk yard sounds like your best bet or just taping it all
Old 07-14-2008, 12:10 PM
Engine: 350 v8
my bad, i am wanting to paint the whole car. The outside, the engine back and then the underside. So basically i am looking for something that i can roll the car on. so i can sandblast the underside and paint that too. i wanna keep the undercarriage off because i dont want any overspray on it(and possible pull the undercoat off my with sandblaster). but i think trying to go around it is going to cause me more grief. basically what im looking for is one of those car frame rollers. The one you bolt to the from rebar and the back bumper bar so i can rotate my car in the air. Basically making it easy to flip over the car so i can sandblast the undercarriage.
i can draw a quick picture if you still dont understand.
Old 07-14-2008, 12:20 PM
Engine: 350 v8
ok so after more searching i have found out its not worth the expense. It will cost 800 + 100 dollar brakets and then it cannot support the doors on the car. so i dont want to go that route either now.i guess i will really need to think about this again
Old 07-14-2008, 02:25 PM
gcgarner's Avatar
Are you talking about a rotisserie? I'd say it's worth the expense if you really want to do a nice 100% restoration job. Most of our cars will never see that attention to detail. Is this going to be a show car or a driver? If it's a driver, then the rotisserie might be a little bit of overkill. But, you can sell it (the rotisserie that is, not your car) once you're done!
