RPO Code question.
Old Aug 13, 2008 | 01:05 AM
smokd u2's Avatar
Car: 04 GMC Yukon XL
Engine: Vortec 5300 V8
Transmission: Hydra-Matic 4L60-E A4
RPO Code question.
Hello, everyone. I am looking into buying a 1991 Z28. I asked the seller for a picture of the RPO sheet and I'm using the RPO Decoder and doing my own research for a certain code. The code is VA7. I understand this means LG4 305ci engine but the car itself is a 5.7 & is confirmed by the L98 & B2L codes. Any help? Thank-you.
EDIT: If it helps any, it also has the 1AZ(special-purpose order) code.
Old Aug 13, 2008 | 11:13 PM
kizz's Avatar
Car: 1982 Recaro T/A
Engine: LU5 CFI 305 V8
Transmission: TH-200C
Axle/Gears: 3.23 F-body Fanatic: Yes
Re: RPO Code question.
That sounds like a fairly unusual one.
This is from a 4thgen-fbody site, so I don't know if it applies, but:
"VA7 : LANGUAGE LABEL, FRENCH"
good luck, GT
Old Aug 13, 2008 | 11:15 PM
smokd u2's Avatar
Anyone? :/
Old Aug 13, 2008 | 11:24 PM
smokd u2's Avatar
Thank-you. I found that also but just needed confirmation.
Old Aug 15, 2008 | 10:34 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
I agree with kizz's results. I checked a couple other sources and as far as I can tell, that's what that code has always meant. I can definitly confirm it has nothing to do with anything regarding the engine/drivetrain. Be very happy with the L98. That's the best engine you can get in a stock 3rd gen.
Good luck with the possible purchase.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
