Hush Panel Years and Differences?
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Im in need of a driverside hush panel for a 5 speed and know there is a difference between years. Example i think the fuse cover location is different and clutch pedal cut out. I have a 89 and need to know what years that the panel was the same and what years i can put one on from. Im sure ScottMoyer might know.
Re: Hush Panel Years and Differences?
Actually, I really don't know. I think the hush panel was the same for each year but different for the manual/auto setup. Again, I'm not sure. Try setting this up as a poll and request pictures of what people have.
Car: 89 IROC-Z
Sorry but i dont know how to set this up as a poll. I can always learn though! anyone set a poll up before please help.
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I agree with Scott, the hush panels were the same, just there was a cutout for the clutch pedal on the manual cars. I took my auto hush panel and cut around the line that was molded in it where the clutch pedal went when I converted mine to a manual.
Car: 89 IROC-Z
Hey thanks alot guys that will help out alot! Now i can go back to that junk yard and get the automatic trans one and cut it out. Dont know what id do without TGO!
Car: 89 IROC-Z
Think that could be because its a Firebird? I dont know, now i guess ill have to find one and see if it fits or not.
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
the drivers side changed for both camaro and firebird in 1990 when the dash design changed. They went from an abs plastic panel held in with the usual 7mm dash screws to a steel plate covered with foam and a rubbery covering similar to that of the dash pad. They are held in with countersunk Allen head screws that receive plastic caps to cover them. I don't know if there were variations in the earlier abs plastic drivers side panels over the years or if there were variations of the passenger side abs panel throughout the 3rd generation years.
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Jeremy comes close. 90+ still has the abs plastic piece as well as the padded panel. It has a larger fuse box cutout, shaped like an "L" since the ALDL is located in the same area on the 90+ cars. The front edge is held in place by metal clips.
There are some variations on the design of the passenger side based on the courtesy light option that I have seen. This could be year dependant.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
82-89 Firebird under dash panels are not the same as the Camaro version. As mentioned, both interiors were redesigned in 90 and got updated trim panels as a result. The Camaro has several different styled trim panels and so does the Firebird. Don't forget that all the AC delete cars also had specific Trim panels to account for the outside air vent boxes. That means there were at least 8 different Camato lower dash trim panels FOR THE DRIVERS SIDE. ( I think all camaros used the same passenger side panel with some later years lacking holes for the courtesy light bulb cover )
Camaro 82-89 Auto
Camaro 82-89 Auto AC delete
Camaro 82-89 Manual
Camaro 82-89 Manual AC delete
Camaro 90-92 Auto
Camaro 90-92 Auto AC delete
Camaro 90-92 Manual
Camaro 90-92 Manual AC Delete
Any under dash panel from an 82-89 Camaro can be interchanged with a little cutting as the mounting points are all the same.
I can only assume that the firebird panels were similar - but the 82-84 dashes might have used yet another additional style due to the early Firebird dash design.
Camaro 82-89 Auto
Camaro 82-89 Manual
Camaro 90-92 Auto
Camaro 90-92 Manual
Car: 89 IROC-Z
Ok i guess ill go get one and try to make it work. If the mounting holes and fuse block cover are the same i should be ok right? other than cutting out the clutch pedal slot?
Car: 1991 Corvette
Engine: 353 cu in
Transmission: M6
Axle/Gears: 3.45
I have the padded panel out of my 1992 Z28 (5.7/auto originally) laying in the garage and can mail you photos if you need them.
Car: 89 IROC-Z
so i dont want to buy one and then it not work out 100%. Ill keep looking for the right one in other yards. Sorry if im
but maybe if we get this figured out it will help other buyers on here decide wich one will fit. Thread Starter
Car: 89 IROC-Z
I asked RCAR7395 (think thats right) if he had any and hes got tons of them. Im hopefully going to get the right one from him with the square fuse cover and everything. Does anyone know how these are bolted or screwed into place? not a big deal but if some special plastic screw thing is needed i dont have it. Thanks guys
