codes and stickers
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
codes and stickers
ok so is there any way to get the RPO codes from the vin? my car did not have a center console when i got it so i dont have the rpo sticker.
second, is there any way to get the stickers on the drivers door reprinted? unfortunately i need to replace my door due to rot and want to save them.
thanks
thanks
Re: codes and stickers
You can contact GM Historical services, pay them $50, and they will get you a copy of the invoice, which has all the RPO codes and cost. Do a search for invoice to get the threads that touch on that subject.
As for the door stickers, you probably will not be able to reproduce them. I haven't heard of a true replacement yet. There are people duplicating them, but they aren't even on a sticker if I remember correctly.
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
i need my two door VIN stickers Replaced where can i get this done?
Car: 82 TA
Engine: Slighty built 350
Transmission: T10
How do you contact GM historical servces? I am a GM employee and have tried to get info on my 82 and been told it doesn't exsit. Records wern't well kept till 84 is what I was told by GM TAC and I was pretty much SOL.
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
thanks
thanks
http://ras001.0catch.com/stickers/stickers.html
He does great work, and it is a perfect reproduction, he made the door jamb, SPID, and VIN security stickers for my Formula a few years back, highly recommended.
As far as the list of RPO codes, you can try to call the PARTS dept of your dealer, they use a different system then the Service dept, they may be able to still access '86 info but I am not sure.
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
2 months ago, I went into my local Chevy Parts Dept. to get RPO codes for a third gen I was thinking about buying. Gave them the Vin # and got a printout a few minutes later. So, it still works, and well worth the time.
hi i still need the door vin stickers done
The GM Dealers in area my wont help me and they tried to sell me a new car instead. PHS does not make door stickers and Russ will not respond to my emails!!! If I did not go through the list. I would not have asked!!!
Thirdgen89GTA
Nov 26, 2015 11:04 PM
