Does Anyone How Much A 88 Firebird Weights?
Car: 1988 Firebird n Suburban
Engine: 350 Small Blocks In Both
I've been trying to find out n i can't so if anyone knows n can tell me that would be great.
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: Does Anyone How Much A 88 Firebird Weights?
look on the door jam of the driver door. Should tell you the weight of your car there.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Car: 89 Formula
Transmission: TH 700R4
scale--we have some unmammed ones just outside of town. Maybe you do?
and weighs is the plural of weight
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
The sticker on the door shows the gross vehicle weight rating (GVWR). That's the maximum allowable weight of the car including passengers and luggage. It's not the actual weight of the car.
It's hard to tell the exact weight of a third gen..... The options have a significant bearing on the actual weight. A V8 weighs more than a six.. Leather upholstery weighs more than cloth... Then there's auto vs standard tranny, T-tops, power stuff etc...
Your car will most likely be in the 3400 - 3600 lbs range.
I don't think thats correct either. Mine says 3250, there's no GVWR next to it. It simply says "vehicle weight". thats for a 84 Z28. I know it'll carry more weight than that with 4 adults.
Axle/Gears: 9-bolt/3.45
GTA Jim is correct. The sticker on my '87 is exactly as his '89, and the sticker on the original poster's car(an '88) would also be like this. And I'd agree that his car is in the 3400-3500# range. The delivered weight of the car would be on the car's invoice(it's probably on the build sheet, too). But the only way to know what the weight is today of his specific car would be to drive it onto a scale somewhere.
Jim's also correct about the options. Each model has a stack of literature about 1/2" thick listing the weight of each available option: a/c, tranny, seats, etc. He mentioned that a V8 weighs more than a V6, but even each different V8 has its own weight. An LB9 weighs more than an L98.
However, Kevin, you say the sticker on your '84 states a specific weight, so obviously you're correct, too. So apparently GM changed the info on the door stickers at some point in time. They changed the cowl ID tag after the 1985 model year, so perhaps that's when they changed the door sticker as well.
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
I never realized that they listed the real weight on the door sticker for some years and GVRW others.. All the stickers I have ever seen had the GVRW. But, to be honest, I haven't seen them all, or paid that much attention.
I just looked on the net and found a door sticker for a 1977 (second gen) Camaro and see they listed the GVRW rather than the actual weight back then too.. I guess for a few years in the 3rd generation they got away from that.
Here's a photo of a 1977 Camaro door sticker showing GVWR
http://77z28camaro.googlepages.com/G...el-sticker.JPG
Anyway.... Out of interest, I have a list of option weights from the Firebird 1990 model year. It was provided by GM. There were a lot of option weights they left out. Here are all the ones they listed:
Firebird 2dr coupe (3.1 V6 + Manual Transmission) --- 3106 Lbs
Firebird Trans am (305TPI + Manual Transmission) --- 3338 Lbs
Firebird Formula (305TBI + Manual Transmission) --- 3338 Lbs
Firebird GTA (305TPI + Manual Transmission --- 3554 Lbs
Add extra weight for:
Power Windows --- 4.8 Lbs
Hatch Roof --- 33.9 Lbs
Air Conditioning --- 41 to 42.8 lbs (depending on engine)
Aero Spoiler --- 15.9 Lbs
4-Wheel Disc Brakes --- 18.9 Lbs
Cruise Control --- 4.9 Lbs
Tilt Steering --- 2.2 Lbs
Engine weights (over 3.1 liter V6)
- L03 5.0L TBI --- 159.6 Lbs
- LB9 5.0L TPI --- 164.9 Lbs
- L98 5.7L TPI --- 181.6 Lbs
And finally, I weighed my 1990 GTA at a certified government weigh scale. (The scale is certified because they use the scale to fine overweight trucks)... With 1/2 tank of gas, my car weighed in at 3658 Lbs.
Car: 1987 Z28
Engine: LG4
3600lbs with you in or out of car?
all 3 of my f-bodies have gwvr on door
83 firebird
85 trans am
92 trans am
83 firebird
85 trans am
92 trans am
Your '83 says GVWR, Jim believes that's always been the case, too, and so do I. I've never seen one with actual weight on the sticker. On the otherhand, I can't say I've always paid attention to the door stickers throughout the years to know that's always been the case. So I'm not going to try to refute Kevin's claim that his '84's weight is on the sticker. Afterall, he's there looking at it, and I'm not.
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
I was in the car, but I subtracted my weight.
GM states that the base 1990 model year GTA with the 5.0L engine and manual transmission is 3554 Lbs... My loaded Automatic 5.7L GTA that weighs in at 3664 lbs is only 110 Lbs over the base model.
My Camaro is in the shop right now so I can't look at the sticker. But here's the paperwork from the smog shop. They also listed the weight at 3250 Lbs, with a N/A for GVWR. I thought maybe I was mistaken about the no GVWR, but assuming GM gives you 900 Lbs for fluids, passengers and luggage, then subtracting 900 Lbs from 3250 would put the car at 2350 Lbs. And theres no way it's that light....No Way.
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
I have the build sheet for my reasonably optioned '84 Trans Am and it lists a shipping weight of 3,424 lbs. The GVWR is 4,215 lbs.
Generally, most 3rd-gens weigh in the 3,200-3,600 lbs range.
theshackle
Aug 23, 2015 03:49 PM
