1984 with 1985 fenders?
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Hi to all
I just bought an 84 trans am...black with the gold striping.
damaged front DS fender.
and motor problem
what I'm finding is that all the 84 fenders I locate do not have the gta vents on the side like my car does. Only for 85+.
is this just a glitch or do you think the fenders were upgraded at some point.
vin checks out as an 84.
I'm prolly just missing something but can't see it.
the car....
and motor problem
the car....
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Re: 1984 with 1985 fenders?
thanks for clarifying
I'm pretty new to this american car scene.
Have a 2000 base firebird but always wanted a KITT style.
I hope to learn alot about my car on this forum.
the thing is that when I searched online for a new fender...all the 84 or earlier had no hole for vent.....only 85+.
thanks alot for the info.
I have much to learn.
Last edited by astrosurfer; 12-29-2008 at 11:09 PM. Reason: afterthoughts.......will do it every time.
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
Yes, all the '82-'90 Trans Am fenders had the vent in them. However, '82-'84 and '85-'90 fenders are slightly different. The upper mounting hole on '82-'84 cars extends out a little further on the earlier fenders. Because of that, you can't use an '82-'84 fender on later cars but you can use '85-'90 fenders on earlier cars. So you will be fine with any '82-'90 Trans Am fender.
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
wow.
I'm glad I did ask.
I had a feeling something was different somehow.
good info...thanks alot.
I'm glad I did ask.
Axle/Gears: 9-bolt/3.45
But the '82-'84 vent is different than the '85-'92 vent. So when you remove and discard the damaged fender from your '84, be sure to keep its vent so you can re-install it in place of the vent from the '85-'92 fender.
