RPO code Y06
Old Jan 23, 2009 | 09:49 PM
1990RSVERT's Avatar
Car: 1986 IROC Z28
Engine: LG4 305
Transmission: Manual T5
RPO code Y06
I have just recently purchased a 1984 Z28, and I was decoding the RPO's and came across Y06, which told me ring gear, 9.50 in Saginaw (SPO). Can anybody out there tell me what that is????? I've been collecting f bodys now for 3 yrs, and have never even heard of it. I would appreciate the help. Thanks 1990rsvert
Old Jan 23, 2009 | 10:16 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: RPO code Y06
It refers to the differential ring gear size. 9-1/2 inch rearend.
Old Jan 24, 2009 | 02:31 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: RPO code Y06
Are you sure? A 9-1/2" ring gear? Stock? In an F-body?
Old Jan 24, 2009 | 10:19 AM
Car: 86 T/A
Engine: 5.0 TPI
Re: RPO code Y06
I'm sure the description refers to the differential. I'm not sure the rpo decoder is correct.
Old Jan 24, 2009 | 10:36 AM
86TARecaro's Avatar
Car: 1986 Trans AM Recaro Option
Re: RPO code Y06
Y06 from 82-85 PANEL, COWL KICK (CARPETED)
Old Jan 24, 2009 | 01:57 PM
Car: 86 T/A
Engine: 5.0 TPI
Re: RPO code Y06
That makes more sense!
Old Jan 24, 2009 | 02:47 PM
1990RSVERT's Avatar
Car: 1986 IROC Z28
Engine: LG4 305
Re: RPO code Y06
So the decoder is wrong? All I need to know is what is it?
Old Jan 24, 2009 | 06:32 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: RPO code Y06
I believe it refers to the panel down by your feet. Is yours carpeted?
Old Jan 24, 2009 | 10:40 PM
1990RSVERT's Avatar
Car: 1986 IROC Z28
Engine: LG4 305
Re: RPO code Y06
Yes, they are carpeted. But the camaro white book calls that a different code. Has nobody else out there had this code??????
Old Jan 25, 2009 | 08:10 AM
L695speed's Avatar
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
Re: RPO code Y06
I also have the Y06 code on my 1984 Trans Am. I am seeing conflicts as well. The TGO RPO decoder has the Y06 as indicated previously as the rear ring gear. WildJeff did a decode that was well done (still some issues but otherwise well done) for the early third gen birds and he has it as the carpeted kick panels. I included two photos of my car with the kick panels in view. I am suspecting the RPO decoder might be wrong it also doesn't have all the codes either.
Because I plan on taking my car to the Hershey fall meet this year I decided to get the documentation for it. I am waiting to recieve my packet from the PHS. That might settle the debate once and for all unless someone already has it figured out.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
