rpo codes 84 ta
Subscribe
Feb 17, 2009 | 03:50 PM
Looking for some help on some rpo codes for a 84 ta.They are as follows= e6n,nod,qhw,yt9,zr6,55m,55p,6uk,7uj.any help would be appreciated.Thanks
Reply 0
Feb 17, 2009 | 04:39 PM
Re: rpo codes 84 ta
QHW=Tires-P205/70R14
55P= Wheels-Gold Turbofins (N24)
YT9=comes up as ??? in RPO decoder so not sure what it is, it has been answered someplace else.
Reply 0
Feb 17, 2009 | 06:49 PM
Re: rpo codes 84 ta
Thanks for the info.
Reply 0
Feb 17, 2009 | 07:09 PM
Re: rpo codes 84 ta
I found YT9 to be reinforced doors
N0D - Dual Exhaust
ZR6 - GM Show Vehicle
Good Luck!!
Reply 0
Feb 18, 2009 | 03:27 PM
Re: rpo codes 84 ta
Thanks.I always wondered about the the show vehicle part.I've owned this car for 19 years and have never seen another with this interior.Anyone else have or seen a interior with medium cognac code 60i and 60b light driftwood.Thanks again for the help.
Reply 0
Feb 22, 2009 | 10:05 PM
Re: rpo codes 84 ta
55M - pretty sure that car would've been painted gold on the lower exterior.
Reply 0
Feb 22, 2009 | 11:37 PM
Re: rpo codes 84 ta
Quote: Looking for some help on some rpo codes for a 84 ta.They are as follows= e6n,nod,qhw,yt9,zr6,55m,55p,6uk,7uj.any help would be appreciated.Thanks
Where do RPO codes come from? Chuck Moehring 84 FBird SE.
Reply 0
Feb 23, 2009 | 12:05 AM
Re: rpo codes 84 ta
Quote: 55M - pretty sure that car would've been painted gold on the lower exterior.
the 55M is indeed gold but not sure on location. These paint codes get confusing with so many spread across ten years
Reply 0
Feb 23, 2009 | 12:17 AM
Re: rpo codes 84 ta
Quote: Where do RPO codes come from? Chuck Moehring 84 FBird SE.
I got your email. First off...to answer your above question.
Your RPO codes should be on the underside of the center console compartment lid. Its called a SPID sticker and it will have several lines of three letter/number codes on it along with your paint code and your VIN. You can take a picture of that and post it and we can help decode it. (Don't post your whole VIN if you do so.) Or you can just list them. Or if you want there is a RPO decoder on the mainpage which you can use and decode them on your own.
To answer your second question about posting a thread you are in the right place with the History/Restoration catagory. Especially if you want to put it back together original. You can post a new thread by simply going to the top of the board and right about the announcements there is a button. Click on that button and you can start a new thread that has to do with whatever you wish to discuss.
While I am a regular on these forums, I don't know it all. My knowledge on cars is spread all over the map from Model A Fords to the High end exotics. Even on these third gen cars there are others on here that can answer some questions better than I can. So don't be afraid to ask others as well. The reason why I have a bunch of info on 84s is because I have the PHS information, and the fact I own one that is original. I also have access to a library that has a signifcant Automotive collection.
Good luck with your car. I can answer any other questions best I can.
Reply 0
Feb 23, 2009 | 02:08 PM
Re: rpo codes 84 ta
Thanks.Mine does have the gold along the bottom.
Reply 0
Feb 24, 2009 | 09:20 PM
Re: rpo codes 84 ta
This my RPO tag from the glove box. I would have never thought to look there.
[ATTACH]172504[/ATTACH
Thanks Chris.
Reply 0
Feb 24, 2009 | 11:12 PM
Re: rpo codes 84 ta
Quote: This my RPO tag from the glove box. I would have never thought to look there.
Thanks Chris.
Chuck
Heres what I got for ya. Keep in mind some of these might be a little off because of the ever changing information but considering I got these from PHS, the TGO RPO decoder, and Jeff's (WildJeff) decode of early third gen birds, they should be pretty accurate.
AAA: 4 way manual seat adjuster
AK1: color keyed seat belts
AM9: Split Rear seat
AR9: Bucket seats
A01: Soft ray glass all windows
B20: Luxury Trim Group
B57: Custom Exterior group
B80: roof drip mouldings
B85: Ornamentation, exterior molding belt reveal
C60: A/C
D03: Paint process water base
D1W: gear speedo driven
D35: Sport OSRV mirrors
D92: Door Handle Tape
E5Z: Speedo Adapter (Delete)
E6N: Speedo Key (Delete)
GU4: 3.08 Rear gear ratio
J50: Power Front Disc Brakes
K19: Air injection system
K64: Generator H.D. 78 Amp
LG4: 305 4bbl. V8 (H code in VIN)
MD8: Turbo Hydra-Matic 700R4
MXO: 4 Speed Automatic
NB1: Emission system closed loop
NB2: California Emissions Requirements
N33: Tilt steering wheel
P06: Wheel Trim Tags
QMW: 195/75R14 Black wall Steel belted radial tires
UP8: Stereo, Radio Installment Provisions
UU7: Radio ETR AM/FM Stereo, Cassette, Clock
U21: gauges, Rally and I.P. Tach
U23: Trip Odometer
U73: Antenna Fixed, Radio
U81: Speaker system, Dual Rear
VAN: Van Nuys Assembly Plant
VD6: Aluminum bumper reinforcement
VJ9: Emission requirements for California
VK3: Front License Plate Bracket
V73: Antenna Fixed
WS3: S/E
YR1: Custom Front Seats
YS1: Custom Rear Seats
YT9: Reinforced Doors
Y06: Carpeted Kick Panels
11L: White Lower
11U: White Upper
22C: Dark Royal Blue Cloth
22I: Dark Royal Blue Interior Trim
229: Dark Royal Blue Seat Belts
The following are computer selected springs
6KR: Left Front
7XU: Right Front
8WA: Left Rear
9UZ: Right Rear
Like I said these are to the best of my knowledge and my info. Some might be off. People might correct them if they check this thread.
Chris
Reply 0
Feb 25, 2009 | 07:34 PM
Re: rpo codes 84 ta
Thank you. That is very helpful. That describes the car perfectly. It still has the original paint. It's born and raised in southern Ca. so there is no rot (so far),and it was garaged most of it's life. The original owner is an old friend of mine. He did'nt want to sell it, so he gave it to me ,if I promised to take care of it. I think I'm going to have some fun bringing it back to it's youth again. Thanks again for your help.
Reply 0
Feb 25, 2009 | 07:40 PM
Re: rpo codes 84 ta
No problem. Glad I could be of help. Also the folks at earlythirdgen.com/forums can be of help when looking for parts, information etc. You will find several of us from here me included over there. It is dedicated to the early third generation firebirds of 1982-1984. There is a ton of information and parts and so on here as well.
Reply 0
Mar 3, 2009 | 02:13 AM
Re: rpo codes 84 ta
Hello Forum..I am a new member here and just getting back into Trans Ams...I have had 13 of them in my previous younger days and just recently bought #14 for my 17 yo. daughters first car...So I hope I am not stepping on the original posters toes by jumping in here but I too have some questions about my new 1984 Trans Am that the RPO decoder could not answer..Here are the 7 codes it could not decipher so any help would be appreciated...
E6N
WS1
WU1
WY5
YT9???
55P
59L
I have learned the meaning of a couple of these from this post, but there are also others that have me baffled for instance this is the one that is stumping me the most
59U---Primary color exterior, Orange Met. (92)
Again I apologize if I have stepped on some toes here and if so please direct/move my post to a more appropriate place
Larry S.
Reply 0
Mar 3, 2009 | 10:29 AM
Re: rpo codes 84 ta
Quote: Hello Forum..I am a new member here and just getting back into Trans Ams...I have had 13 of them in my previous younger days and just recently bought #14 for my 17 yo. daughters first car...So I hope I am not stepping on the original posters toes by jumping in here but I too have some questions about my new 1984 Trans Am that the RPO decoder could not answer..Here are the 7 codes it could not decipher so any help would be appreciated...
E6N
WS1
WU1
WY5
YT9???
55P
59L
Larry S.
WS1: Pontiac Excitement Plus (this is one of many savings packages if you order certain options on the same car I have the same thing with WS5 on my own 84 TA)
WU1: Instrument Light Shutoff Switch
WY5: Special Handling Package without Limited slip (Should not have G80 on your sticker)
YT9: Reinforced Doors as mentioned somewhere above.
55P: 55 is Gold Color P is location. From what I have 55P stands for Gold Turbo Finned Aluminum Wheels (N24)
59L: Color on lower part of the car 59 is Beige
59U: Color on upper part of the car 59 is Beige
I used PHS documentation to get this information as well as searching the threads for WU1 which was answered elsewhere.
You seem to have a one color car from the factory. The car appears to be repainted from what I see of the Grille inserts on the front. Those were Black on all cars.
Also just to let you know, you will probably find more information here:
It is dedicated to the 82-84 Firebirds you will find a bunch of us from here on TGO over there as well, myself included.
Hope this helps.
Chris
Reply 0
Mar 5, 2009 | 06:39 PM
Re: rpo codes 84 ta
Just wondering what color is your interior?Can't really tell from the pictures but it kind of looks like mine.Nice car by the way.
Reply 0
Subscribe
