casting #
Car: 91 gta and chevy powered toyota
Engine: 5.7 in both of them
Transmission: 700r4 raptor
casting #
I JUST PULLED A MOTOR OUT OF A 91 TRNS AM ,IT HAD ALOT OF AFTERMARKET THINGS DONE TO IT,,TPIS MINI RAM TREMEC TKO600
AND AFR ANGLE HEADS ON IT ,,I TRIED TO FIND OUT WHAT BLOCK IT HAS.I HAVE HAD NO LUCK ,,NO SUFFIX NUMBERS ON THE FRONT ..AND ON THE BACK ALL THER IS ====(5.7/LG )UDERNETH THAT(AGI) THEN TO THE RIGHT ON AN ANGLE THERE IS (A129..).CAN ANYONE HELP ME FIND OUT WHAT KIND OF BLOCK THIS IS?
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: casting #
What letters/numbers are stamped on the block in front of the passenger side cylinder head?
Once you get these, check here:
http://www.nastyz28.com/chevy-engine-code-stampings.php
Re: casting #
Thanks !
skinny z
Oct 5, 2015 06:23 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
355tpipickup
Sep 13, 2015 11:35 PM
