is it a berlinetta?? 86'
Car: 86 carmaro t top
Engine: v6 2.6
Just got my 1st carmaro that i always wanted i think i might have got extra lucky. if i read that chart under the 1986 models right the berlinetta was the only car made in 1986 with a v6 and a 2.8 and thats what mine is my dad says everyrhing looks factory...also has t tops....so do i have a berlinetta?
thanks crystal
thanks crystal
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: is it a berlinetta?? 86'
Congrats on your ride!
The LB8 2.8L V6 was available on both the Sport Coupe and the Berlinetta (it's base engine). So going only by the engine, you can't determine 100% that's it's a Berlinetta.
An easier and simpler way to determine if you have a Berlinetta is that it was the only model to have the futuristic electronic instrumentation (digital gauges, automated radio controls, etc). Got that and you have a Berlinetta. If you have regular analogue gauges, then it's the base Sport Coupe.
Engine: v6 2.6
Thanks ...i guess shes not but i love her anyway she runs so well...any advice on paint jobs i want to keep her as original as possible and slowly restore her. she needs allot of love
crystal
crystal
Axle/Gears: 3.08
There are a great number of variables that play here.
- What is your budget? A good basic paint can easily run inot more $$$ than the car is valued at.
- Body condition. Depending on how much work the body needs and how well you have it prepped (patching holes, cutting out rust, replacing with metal or bondo short-cuts, straightening parts, etc, etc) can equate to as much or more than just the paint job.
- The kind of shop you take it to. A speciality shop or a typical fender-bender fixer-upper place.
- Removing trim and accessories before painting or just masking around stuff.
There are even many more factors that play into it. I'd definitly get a few estimates (at least half a dozen) as to what it would cost depending on how much detail and quality you want or can afford.
Ask around for references. Talk to people at car shows what they've had done, where they had it done, how much $$$.
Prices can range from as low as $500 for a quick cheap Maaco type job that will look OK from a distance and will likley need to be redone in a few years to easily $4000-$5000+ for a good quality restoration.
Any pictures?
Any pictures?
Axle/Gears: 3.08
PS; A good idea for better replies to your question would be to post it as a new topic here or under our Auto Detailing and Appearance board.
Right now we're under the topic title of "is it a berlinetta?? 86'", which has nothing to do with paint jobs.
Car: 1985 camaro Berlinetta 88 firebird
Engine: v8
Transmission: 4 speed
the 2.8 motor is peace of crap you dont save any gas i have 88 firebird with a 2.8 and my v8 camaro gets about the same gas i think the 2.8 gets like maybe 2 miles more then the v8 the base camaro where mass produced as well compared to Berlinetta now days thers less and less berlintta witch mean they will be rare conpaird to z28 or iroc so guess what that car price will go up more then the rest and since it was onley made in the 80s for a short run it will be hard to find parts but a lot of z28 parts fit the berlinetta the onley true difrence is the dital gage and pod and the rims body sysle the same hood the same motor the same less you got the very rare 5.7 so if you really want to you can slap z28 stickers on it and change a few thing to make it a z28 if you want lol but your tittle still will say berlinetta
Linson
Oct 1, 2015 09:50 PM
manifoldsrme
Sep 17, 2015 11:40 PM
