Looking For a Thid Gen, Help! ????
Old May 15, 2009 | 01:11 PM
marvb549's Avatar
Not sure if this is the right place, but new member, first post and am trying to get some insight.
I am looking to pick up a third gen to add to my collection. Avid camaro fan, but never did get a chance to own a third gen and really want to fix that.
I am looking for an IROC era car, 85 - 90, but need some background and help on what would be considered the best of the run to pick up. I am leaning to 87 right now with a 350.
I currently have a 75 LT and have owned three others in the past. two second gens and a 4th. Will soon have another Z28 4th gen and my 2010 SS.
I am trying to make a low bubget generations collection. At this point I have everything but first and third.
Any help would be very greatly appreciated.
If I put this in the wrong spot, my apologies. Still trying to learn the organization.
By the way, you guys have some really beautiful cars on here!! I can't wait to have my own.
Thanks!
Old May 15, 2009 | 01:15 PM
f1ls1's Avatar
Car: 1999 F-1 Camaro Conv 1990 Iroc-Z
Engine: LS1/L98
Transmission: A4/A4
Axle/Gears: 3.23/3.27
Re: Looking For a Thid Gen, Help! ????
I'll sell you my 1990 5.7 Iroc. Asking $18000.00 OBO
ll
Old May 15, 2009 | 04:15 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
My preference is a 88-90 iroc. If i ever buy another iroc it will HAVE to be an 89 L98 G92 car with less than 50K on the clock. There's one for sale here in MN but he wants ALOT of money for it, But not 18,000 like the previous post.
Old May 16, 2009 | 03:39 AM
marvb549's Avatar
ll
Nice looking car, but way over my budget. I am just trying to do some research to find out what would be the best model year to look for. Not quite ready to buy yet until I can get some solid info on the best way to go. Don't really care about rare or collectible, just a solid car that would be the best year of the run.
I do love the car and have seen pics of it on other threads. Very good job keeping it up.
Old May 16, 2009 | 03:45 AM
marvb549's Avatar
Originally Posted by 89ROC-Z
My preference is a 88-90 iroc. If i ever buy another iroc it will HAVE to be an 89 L98 G92...
Thanks for the info. If my research serves me correctly, L98 is engine and G92 is suspension. Why do you consider these years to be better than the rest? I have seen a few '89 MY for sale with a 350, so that would be easy to come by I think. Have to research the G92 specificaly on the ones I have seen.
What differences on the '89 make it a better car than the previous years?
Any help would be greatly appreciated.
Thank you!
Old May 16, 2009 | 09:37 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Sorry i can't beleive i didn't explain that in my post!
L98 is the 350 tuned port injection introduced in 87. You could ONLY get an Automatic with the 350.
G92 is a "performance" package. It consisted of (please correct me if im wrong guys) Dual Cats, Rear Discs, a 3.42 gear ratio, And a 145 mph speedo.
Now i like the model year 89 for a number of reasons: It looks good (all camaros do ), It was the last year for no airbag, last year of the square dash, first year for VATS (a security feature), And the TPIs got rid of the cold start injector.
But remember it's YOUR money and will be the car YOU drive and care for, so in the end its still all your choice!
Old May 17, 2009 | 10:47 AM
marvb549's Avatar
Thanks. That is the kind of info I am looking for. If I remember correctly G92 and AC delete triggered the 1LE correct? G92 will be a good ne to look for.
Old May 18, 2009 | 10:42 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The above mentioned 3.42 gears were only available with the 5 speed. The gear ratios are 3.23 or 3.27 for automatic G92 optioned cars and 3.42 or 3.45 for 5 speed cars. The reason for the 3.23 or 3.27 gearing is tied to the 10 bolt or the 9 bolt Borg-Warner rear ends.
Old May 18, 2009 | 03:19 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Thanks for the correction Scott! BTW, your new sig looks awesome
Old May 18, 2009 | 03:45 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Scotts car is well.. Awesome! :hail:
It will really depend on what your after, I do not know how much of a difference an L98 will make in the future based on year alone. Here are some things to consider
Camaro's
1987-1989 you could get T-tops with the 350, 1989 being by far the most popular year for the combination.
Personally I would look for one like Scotts that had BOSE, then chances are you would have gotten just about all of the other options like Power windows, locks Cruise etc...
1987 the IROC was an OPTION for the Z28...
1988 + had the serpentine belts. Z28 was no longer available by itself, you could only get a Z28/IROC in 1988 thru 1990.
1989 - 1992 the 9th injector was dropped, they also changed the fuel injectors, unfortunately the injectors appear to fowl more easily than the 1987 & 1988, causing the engine to run rough.
1990 - 1992 T-tops were no longer available with the L98 (350)
1990 was a partial production year, they only made the IROC thru the end of 1989 so production is limited.
1991 Production started in February of 1990, the IROC went to Dodge and the Z28 returned. The Hi-rise Wing spoiler was introdued, love it or hate it, definitely an acquired taste personally. They also changed the hood blisters...
NOTE: You could not get a Manual with the 350, do not be fooled, none were made, many people either swapped a 350 in for a 305 or swapped in a Manual trans...
Look at the VIN, make sure it is an ( 8 ) 1G1FP218 for 1987 - 1989, and 1G1FP238 for 1990 - 1992.
I am not 100% on this, but I think for the most part all L98's got the performance gear ratio (3.27 from 1987 - 1990, or 3.23 from 1990 - 1992) there was a mid year change from the B&W 9 Bolt to the Saginaw Gear early in 1990 IIRC.
My personal favorite year is the 1989, It has the hottest cam, I honestly got 26 Mpg on the highway in my convertible 350, when it is just me (no passengers or luggage).
Hope that helps
Old May 18, 2009 | 05:16 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Mine's a 90, but is this low enough:
Old May 20, 2009 | 08:41 PM
marvb549's Avatar
My personal favorite year is the 1989, It has the hottest cam, ...
All of the info in this response was very helpful. I have quoted the above because they are what I found that leads me to desire the earlier years more than later. I find that the 85 to 87 Camaros's were true Z28 models with the Iroc badging and additional features, but they were true Z28 Models. After 87, they all became IROC and the Z28 was not a true feature as much as IROC was the hype. Maybe my logic is incorrect, but that is why I am here to be educated on the differences. SO far it does look as though I am leaning to an 87 or 89, but I definitely would like a nice thrid gen to add to my collection, and I have always loved the look of these cars. I want an IROC simply for the place in automotive history that holds for the Camaro. My collection I am trying to build is not for investement purposes, but merely to collect the best of each generation and have a collection that represents Camaro history. All I need is a first and third and I will be there. Third Gen's are much easier to come by right now than first, so it is my current focus.
I may settle for a first gen project and restore it to get where I want. Unfortunately I missed the entire third gen run being overseas in the Military and am just very much behind the power curve on these models.
I really appreciate the help so far and any additional information to help me will be greatly appreciated.
Old May 21, 2009 | 08:05 AM
okfoz's Avatar
Honestly for 1985 & 1986 Chevrolet had the following models
-SC aka Sport coupe
-Z28 - An SC option
-IROC-Z - a Z28 option
-Berlinetta
1987 was like 1985 & 6 but with some minor changes
-SC aka Sport coupe
-RS - An option on the Sport coupe in limited areas
-LT - An option on the Sport coupe
-Z28 - An option on the SC
1988
-SC aka Sport coupe
-RS - An option on the Sport coupe, again in limited areas
-Z28 - Automatically upgraded to IROC-Z
1989 - 1990
-RS - replaced SC as base model
1991 - 1992
-RS - no other packages
-Z28 - no other packages
So technically the Z28 never went away, but you could not get "just" a Z28, you automatically got the IROC... I think it had to do with trends and the fact that the Z28 would have been more costly due to the different color ground fx.. more paints to mix & match.
John
Hotrodboba400
Dec 10, 2019 07:07 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Stryker412
Sep 7, 2015 09:11 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
