question on 92 camaro check digit
Old May 21, 2009 | 11:37 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
hi i have a 92 rs and the check digit is a x is this common my insurance company said it was a invalid vin and to recheck the car but the x is correct
just wondering
Old May 22, 2009 | 02:15 AM
yo soy el warg's Avatar
Re: question on 92 camaro check digit
just wondering
This 'X" is not common but it is valid. I just ran a Vin# on a 1985 Camaro with the same "X" as a check number. If you want a copy of that Car Check let me know and I'll Email it to you.
Old May 22, 2009 | 09:29 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The Check digit is calculated by assigning a number to letters, and then multplying each number by an assigned number for the position. (except check digit) you add up all of the numbers and the divide by 11. you will end up with a remainder. You always round up...
Examples
if your remainder is .090 then you have a check digit of 1
If your remainder is .402 then you have a check digit of 5
If your remainder is .909 then you have a check digit of X
If you do not have a remainder, suppose that your total is 275, then you divide by 11 you get 25 then you have a check digit of 0 (zero)
Chances are you are misreading a letter or number.
John
Old May 22, 2009 | 09:35 AM
okfoz's Avatar
By the law of averages, Chances are one out of every 11 cars has a check digit of X
John
Old May 22, 2009 | 10:36 AM
RPM WOT L 98's Avatar
I think what John means is that you may be misreading one of the other letters or numbers in the VIN. "X" is a valid check digit though.
Old May 22, 2009 | 08:28 PM
driver101's Avatar
the insurance company said the x was invaild i now understand x is valid and will correct the problem with them as the vin i gave the was correct they stated the x was the problem
thanks for all the info
luke
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
beachrodder
Aug 7, 2015 04:27 PM
