Help with 86 Iroc Z28 trade
Old Jul 22, 2009 | 06:49 PM
86_iroc_z28's Avatar
New to the board!
Looks great.
I have a chance to trade my motorcycle for this.
I need some help as to the key areas to look at. Places rust will be hiding!
He claims: New brakes/rotors; new master cylinder; engine/tranny rebuild.
Does not have current inspection due to hole on driver's side floor.
Odometer is around 75,000 May be going to see it on Saturday.
I am not opposed to repairing a little at a time but do not want to get a rust bucket!
Attached Thumbnails Help with 86 Iroc Z28 trade-1986-camaro-iroc-z28
Old Jul 22, 2009 | 06:54 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: Help with 86 Iroc Z28 trade
Hole in the floor? Sounds like it already has rust issues.
Old Jul 22, 2009 | 07:37 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
what kind of motorcycle will you be trading? usually rust hides under the gfx and around the bottom of the doors.
Old Jul 22, 2009 | 07:40 PM
2001 Yamaha VStar 650 Custom
Old Jul 25, 2009 | 06:09 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Do the trade. You will live longer.
Old Jul 25, 2009 | 07:05 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
See if you can get under the car with some good light (sun, flashlight, etc). Have a good look around for anything that spells trouble. Any bad rust or corrosion.
Also regarding rust, look closely at the headliner, seats and carpet for any unusual stains or water marks.
Other things . . .
- Can you run the car? How does the exhaust look? Normal, blue smoke, etc? Then check all the options (AC including fan speeds and different vent locations like defrost and floor, lights, wipers, seats, windows, door locks, etc).
- Open and close both doors, hood, and rear hatch. Do they work OK. Do things line-up?
- How are the seals (weatherstripping)?
Frozer!!!
Jan 19, 2024 04:55 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
mustangman65_79
Aug 11, 2015 03:17 PM
