Is my car a true iroc??
how do i know if my car is a true iroc? the year is 1985 and the engine is an TPI, the dash emblem says z28 iroc z and i read somewhere that if you look at the parts list inside the console box and it says B4Z that its an iroc....the guy that sold me the car had it primerd black but the color before it looks greenish because i can see the other color in some parts....i havent seen any green irocs before...let me know!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Is my car a true iroc??
JamesC
Car: 1988 IROC
Axle/Gears: 3:27 9-bolt
Were the 16" wheels (N96) available on the Z28, or just on the IROC? My 85 doesn't show the B4Z code, but does show the N96 wheels.
JamesC
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
in 1985 the only colors available on the iroc-z were-silver metallic, black, bright blue metallic, yellow and red. that info is directly out of my original 1985 chevrolet camaro showroom brochure.
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
To expand on what James and Stevo stated, check the RPO sticker (located inside the center console) for B4Z. More importantly, make sure the VIN code (also on the sticker) matches what is on the dash.
Just like the dash emblem and exterior decals, a center console can be swapped as well.
poke your head underneath the front end of the car-directly behind the radiator should be a round bar with stamped end flanges welded to it. it bolts on each side to the left and right subframe rail. it was called the "wonderbar" and only irocs had it from the factory. it stiffened the frame somewhat. if it is there does it look like it is original? factory fasteners and wear and tear dirt to go along with the vehicles age? if it lokks original your car was prolly an iroc.
JamesC
thank you for that clarification. it makes me wonder if anyone reading this post has ever seen a f-body with subframe damage (ripped out steering boxes, bent framerails, etc from too much grip on the road. not collisions. just fatigue and wear and tear. like the old dodge b series van where the steering box would actually rip out its mounting points and spin in the frame as you steered it. (maybe a new thread is required)
mustangman65_79
Aug 11, 2015 03:17 PM
