Is there a difference?
Old Jan 11, 2010 | 10:04 PM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
I'm wondering if there is a difference between an 84 Z28 and a base model 85? I already have the Z but would like to get the 85 because it doesn't have the electrical mess that my Z does and the heater works. I have a lot of newer parts on my car that I would like to transfer such as the radiator, hood and trunk shocks, brakes (all of it), and other random things. Thanks for any help you can give.
Old Jan 13, 2010 | 09:26 PM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
Re: Is there a difference?
No one has any input???
Old Jan 13, 2010 | 11:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Assuming they already have the same engine, the only difference will be in suspension components.
Old Jan 14, 2010 | 06:05 PM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
What's different about the suspension?
Old Jan 14, 2010 | 06:34 PM
AmorgetRS's Avatar
The suspension on the Z is better, however that will swap on the 85. It isn't different as far as design, just stiffness. Everything you listed in your original post is compatible from 82-92.
Old Jan 15, 2010 | 06:36 PM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
Thanks...that's what i was thinking but wasn't sure. You guys rock!!!
Old Jan 18, 2010 | 10:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Apart from the swaybars, anything that's different between the two is long since old and worn out. You'd be better off with new replacements.
69GTOby
Apr 18, 2016 02:34 PM
scottmoyer
Sep 20, 2015 11:54 AM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
