WANTED: 1985 IROC-Z Buildsheet or Invoice info
Old Jan 14, 2010 | 08:06 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
It has been found that some 1985 Camaros have an RPO of B9K. I have been unable to locate the definition of B9K for a Camaro. I found it on other websites, but not in any relation to an F-body. I need someone with either an invoice or their original buildsheet for an 85 Camaro that has B9K to post the definition. While we're at it, if anyone has Z5V on their 1985 Camaro Invoice or buildsheet to also display it's identity. Thanks.
Old Jan 14, 2010 | 08:42 AM
mr396's Avatar
Car: 2003 BMW E46 M3 Vert
Engine: 3.2 I6 M power 333 h.p.
Transmission: SMG 6 speed
Axle/Gears: 3.62 posi
Re: WANTED: 1985 IROC-Z Buildsheet or Invoice info
Member 89RESTO is the orig. owner of a 1985 IROC. Go to this thread https://www.thirdgen.org/forums/hist...rd-owners.html and scroll down to where his spid and invoice are posted. His IROC has the B9K RPO but doesn't have side body moldings, and the B9K RPO isn't listed on the invoice.
Old Jan 14, 2010 | 09:22 AM
scottmoyer's Avatar
Checking the options list on 89RESTO's invoice tells me that B9K is not an orderable option. His invoice does not list the option code, however his SPID label shows it. That tells me that the RPO can only be defined by the buildsheet.
Old Jan 14, 2010 | 04:50 PM
yo soy el warg's Avatar
Here is a 1985 Iroc-Z that was on Ebay with 8,000 original miles on it. The SPID was posted and the build sheet. What is interesting is that the B84 and the B9K are both on the SPID. But, the build sheet only lists the B84 and doesn't seem to list B9K on it, or I can't find it. All of this is quite puzzling.
Bigger SPID sheet
Largest build sheet available was this one.
Old Jan 14, 2010 | 06:18 PM
scottmoyer's Avatar
Based on these findings, it is now proven that the riveted door moldings were not a factory option. Holes being drilled in the panels so that a molding could be installed would need to be marked on the build sheet and should also be on the invoice for billing. Without it being there, the line workers would not know which molding to put on and the moldings wouldn't be charged for.
I did contact a friend at GM in Detroit this morning asking if he could help me locate B9K and also Z5V. He said he will see what can be found and let me know.
Old Jan 14, 2010 | 06:57 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This, for what it's worth, from my GM PRODUCTION OPTIONS booklet: RPO B9K.
RPO Name: ORNAMENTATION
Divisional RPO Description: B/S MLDG REAPPLY TO RR DOORS ONLY
I have no idea what any of that means or whether it's significant or not, but there it is.
My 85 IROC has both RPO B9K and B84.
JamesC
Old Jan 14, 2010 | 07:29 PM
daveb123's Avatar
Car: 82 Z28
Transmission: BW T-10
Mine has B9K as well., the car does have what appears to be factory door moldings.
Old Jan 15, 2010 | 12:58 PM
calroc's Avatar
B84 on neither spid or invoice, but B9K IS on my spid (not on invoice), and I can assure you it never had side mouldings of any kind.
Old Jan 15, 2010 | 08:14 PM
mr396's Avatar
My 85 has the B9K and the side moldings. I don't really care for the molding so Im glad it's not a factory option. My IROC does have custom cloth interior. How about you other guy's with the B9K and no B84, Is your interior's cloth? It just might be for the cloth trim processing order.
Last edited by mr396; Jan 10, 2012 at 05:43 PM. Reason: more info,link didn't work
Old Jan 21, 2010 | 05:05 PM
Brother Al's Avatar
Car: 1984 RPO "Y84" Recaro T/A
Engine: HO 305ci L69
Axle/Gears: WS6, J65, GT4: 3:73, G80: posi
Interesting RPOs. I also have a copy of a GM RPO book and have posted all of the info onto www.necamaro-firebird.org & www.earlythirdgen.com
I add any new RPO's & details that I come across. I have the pretty much the same info as JamesC for B9K but nothing for Z5V.
Looking at the RPO's next to them on my list and the current B9K details, is it possible that those are for the "Iroc-Z" decals &/or possibly the ones on the ground FX??
Fanatic1074
Oct 3, 2022 05:57 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
tmellott89
Oct 14, 2015 02:06 PM
88CamZ
Oct 8, 2015 10:29 AM
Eric-86sc
Sep 28, 2015 11:37 AM
