Decoding / locating tags
Old Feb 12, 2010 | 04:22 PM
Samw1's Avatar
Hi all im new to this site but not to the car world. I have a 77 camaro im working on. Just got a 1992 firebird that went up in flames, in the rear and it is repariable. I got the vin decoded by carfax and it said it had an origanal 3.1 v6 but it has a 2.8 right now, im trying to locate the trim tag but am lost as to were it might be, I read on here somewhere that the build sheet is in the back end under the carpet, well if that is true its gone now. I dont know if 92's came with trim tages somewhere but if they did could you tell me where they might be. Here is the vin if you can decode it further for me like make location, body style, ect. 1G2FS23T2NL215492. I found a number right in front of the radiator rivited the the body it reads 050378. I dont know what it is so maby you can help me, thanks all im going to try to post pics of the car damage.
Old Feb 12, 2010 | 05:08 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: Decoding / locating tags
No trim tags on the 92. Based on your VIN, the compnine.com website shows these options.
Vehicle: FIREBIRD 2 DR
Year: 1992
Build Date: 1992-03-19
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)
UM6 RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK STEREO CASSETTE
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS
U62 SPEAKER SYSTEM,4,DUAL COAX FRONT,DUAL COAX PACKAGE SHELF 4 SPKR SYS
VAN PLANT CODE VAN NUYS, CA, CPC VAN NUYS,CA PLANT CODE
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT
W68 PACKAGE,FIREBIRD SPORT APPEARANCE APPEARANCE PKG
1SC PACKAGE-OPTION 03
1SZ PACKAGE OPTION-
52P WHEEL COLOR,GOLD METALLIC
6XS COMPONENT FRT LH COMPUTER SEL SUP (6XS) SUSP
64C TRIM COMBINATION CLOTH, LT BEIGE
64I INTERIOR TRIM,LIGHT BEIGE
649 SEAT BELT COLOR,LIGHT BEIGE
7XS COMPONENT FRT RH COMPUTER SEL SUsP
8UY SPRING-COMPTR SELECT RR LH SUSP
81Q MOLDING COLOR - BRIGHT RED
81U EXTERIOR COLOR,PRIMARY,BRIGHT RED
9UY SPRING-COMPTR SELECT RR RH SUSP
AAA Unk.
AJ3 RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK
BC8 ORNAMENTATION,INTERIOR,FRONT DOOR MAP POCKET RH AND LH DR MAP PKT
B84 BLACK BODY SIDE MOLDING BODY SI MLDG
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT
DC4 MIRROR,INSIDE,REARVIEW TILT,DUAL READING LAMP I/S DUAL READING LP RR VIEW MIR
DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED)
D3V GEAR-SPEEDOMETER DRIVEN (25513046)
D8N SENSOR VEH SPD (10456088)
D80 EXTENSION,REAR END PANEL(SPOILER) R/END PNL MOUNTED RR SPLR
E5Z Unk.
E9Z Unk.
FE1 SUSPENSION SYSTEM,SOFT RIDE SOFT RIDE SUSP(FE1)
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5)
IPC TRIM,INTERIOR DESIGN
J41 BRAKE SYSTEM,POWER,FRONT DISC,REAR DRUM(CAST IRON) CAST IRON FRT DISC/RR DRUM BRK SYS
K60 GENERATOR,100 AMPERE 100 AMP
LH0 ENGINE,3.1L(3.1T),V6(EXPORT) 3.1T(LH0)(EXPORT)
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS
N36 STEERING WHEEL,SPORT-4 SPOKES SPORT STRG WHL
N90 WHEEL,15X7(CAST ALUMINUM) AL WHL
QPH TIRE ALL- P215/65R15/N BL R/PE ST TL AL2 (9591591) TIRE
R8I Unk.
T96 LAMP,FRONT FOG FRT FOG LP
Old Feb 12, 2010 | 10:31 PM
Samw1's Avatar
WOw this is so awsome thank you. I have a question about all these codes, i have the RPO decoder downloaded and ran a few threw they came up the same, but on the code 1SC what dose it mean option-3? or where can I find info on the meanings of the codes. Thank you for your help.
Old Feb 12, 2010 | 11:09 PM
Drew's Avatar
Your best bet is to look in the sales brochure for a 92 Firebird. Just shooting from the hip, 1SC on a 92 Firebird would be the top comfort package... Basically all the power options, fully loaded.
The definitions from compnine are mostly accurate, but they aren't specific to 82-92 cars, so some of them are bit wonky. Use the thirdgen.org decoder if you want a little more accurate definitions.
Elephantismo
Feb 13, 2019 12:51 AM
6998poncho
Sep 25, 2015 02:56 PM
F-body-fan
Sep 24, 2015 08:29 AM
Jlanz55
Sep 6, 2015 02:35 PM
tonys91rs
Sep 2, 2015 07:07 PM
