Engine code
Old Feb 20, 2010 | 07:34 PM
KUNAGUERO66's Avatar
Car: '88 I-ROC Convertible
Engine: 5.7 TPI
Engine code
So i got my code vin thing, i decoded all but the last three digits which would tell me what type of motor it is the last three digits is clh, one website says its a 350 off a 70's cprvette, but im skeptical as it has a tpi system and centerbolt valve covers, another website says its a 305 off a 91 firebird or trans am, how can i figure out which it really is?
Old Feb 20, 2010 | 07:38 PM
Drew's Avatar
Re: Engine code
The place to start is the casting number on the block. It'll be behind the drivers side head on top of the bell housing flange. Then there's the vehicle specific stamping in front of the passengers side head on the top surface of the block. Finally, remove a valve cover and there will be a casting number that identifies the heads.
If the stamp in front of the passengers side head has a VIN number that matches the cars, it's the original block.
http://www.mortec.com/location.htm
http://www.mortec.com/locatpg2.htm
Old Feb 21, 2010 | 05:43 AM
Engine: 5.7 TPI
Re: Engine code
Thanks, i already have some of those codes i guess i have to go find the other ones, oh by the way, the last three digits that i cant decode are clh.
Old Feb 21, 2010 | 08:29 AM
Drew's Avatar
Re: Engine code
http://www.nastyz28.com/gm-chevy-cod...s-suffix-2.php
Google rules.
Old Feb 21, 2010 | 04:17 PM
Engine: 5.7 TPI
Re: Engine code
Thanks, thats the same website i was looking at, and there's three that start with clh, im almost sure now that its a 305
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
