LU5 question????
Old Dec 21, 2012 | 12:50 PM
  #51
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: LU5 question????
From his top secret build, to needing a computer for his mostly stock crossfire.
https://www.thirdgen.org/forums/elec...rade.html:huh:
Old Dec 23, 2012 | 08:18 PM
  #52
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
https://www.thirdgen.org/forums/elec...ade.html :huh:
Old Dec 23, 2012 | 08:33 PM
  #53
82tarecaro's Avatar
https://www.thirdgen.org/forums/elec...r-upgrade.html
Old Dec 25, 2012 | 08:31 AM
  #54
KITT1983's Avatar
ebl flash
http://www.crossfireinjection.net/catalog.htm
http://www.dynamicefi.com/EBL_Flash.php
* Crossfire Corvette:
For the EBL Flash ECM to work in a Crossfire car some additional changes are required. This is due to the type of connectors each ECM uses. The Crossfire ECMs use an edge card connector, while the EBL ECMs use the pin style connector.
Basically there are three options:
1) Replace the EFI harness with one from a TBI car/truck with the proper connectors.
2) Cut off the current ECM harness connectors and splice on the pin style connectors.
3) Have a HAM board installed into the EBL ECM. See DCS at http://www.crossfireinjection.net for the HAM board & install.
HAM Board
Item Name: HAM Board (IN STOCK)
Item Price: $130.95
Item SKU: DCS00013
Shipping USPS Flat Rate: $12.50
IN STOCK
Product Description Convert the GM 127747 or 1228746 TBI ECM to be plug and play compatible with the existing stock CFI harness connection. No need to splice your stock ECM wire harness. Just install the HAM module into the new ECM, plug it in and you are ready for laptop tuning. NOTE: Unsoldering and re-soldering procedures are required to the ECM board for installation, additional hardware and software may be required.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
