Found this in my car , what is it ?
Old 03-11-2010, 11:44 PM
Roc THIS's Avatar
Car: 87 Yellow Iroc-Z
Engine: 5.7 TPI
Axle/Gears: BW 9 bolt
This was under the carpet under the passanger front seat . The hole in it is from the stud where you bolt the seat down . I think its like a factory build sheet . Though I could be wrong . Either way I think its a cool find.
These were also found under the dash pad . Again not sure what they mean but cool anyway.
Size:  48.5 KBName:  100_1343.jpg
Old 03-11-2010, 11:54 PM
Stephen's Avatar
Car: 87 GTA
Re: Found this in my car , what is it ?
Yep, assembly build sheets.
Shows RPO codes for stuff to be instaled/what as installed/checked off etc. Like the one under the dash, it probably indicates that the gauges/lights were hooked up, tested & passed. Right?
I found my dash one. Haven't ever pulled the carpet & looked for others.
Old 03-12-2010, 12:20 AM
Administrator
IROCZTWENTYGR8's Avatar
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Yes, that's one of the assembly sheets, but not the actual build sheet.
Azrael91966669
25
06-20-2017 04:04 AM
mustangman65_79
09-01-2015 03:51 PM
jharrison5
08-19-2015 05:53 PM
marcusaw
08-10-2015 08:13 AM
antares57
08-06-2015 07:47 AM
Quick Reply: Found this in my car , what is it ?
