1991 Z28 question
1991 Z28 question
I found a 1991 Z28 camaro 5 speed car. It has the 140 mph speedo. Should it have a a 3.42 posi disc rear end? Will it have the G92 option? Could it have drum brakes? Where is the RPO sticker?
Thanks,
Brandon
Thanks,
Brandon
Re: 1991 Z28 question
RPO sticker should be in either the center console or in the driver side rear locking hatch. Sometime in 91 they moved it.
It could have drum brakes and it could (probably) has a posi. G92 I am not sure of, the 350 required it, and for some reason I am thinking so did the 305 5-speed, but a quick search only showed that the 350 required it and the tech data backs that G92 wasn't required on it. If it has G92 then it would have a 3.42, without G92 it's a 3.08
https://www.thirdgen.org/1991-chevy-camaro
It could have discs or drums, drums don't rule out G92 for 1991 either.
G92 cars, I believe, will have the dual cat setup.
The HP rating depends on G92 or not.
No, but I can get the VIN. Compnine.com did not work for my 1991 trans am convertible. Is this a good car to get?(z28) Is the production low? This is a hardtop, 5 speed car.
That said, it appears part of their unaccounted for 1991 is roughly 127 Convertibles. They have 548 1992 Trans Am Convertibles in their database while we show 555 being built.
Did you happen to check a few days ago? There was an issue with their database, and all queries were coming up empty. Was that possibly when you checked their database for your 1991 T/A Convertible? The issue was fixed. I'd try your VIN again.
Ok, so how is that any different then what I said? The price went from 2k to 800 bucks... anyway, I think it's a good deal. I don't like hard tops, but a 305 5-speed w/ G92 is a pretty desirable car, imho.
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Not necessarily. Unless it was drastically different for Firebirds. My 1987 Trans Am had the 305TPI engine and the 140MPH speedometer as well as an automatic transmission. As far as I know the 140MPH speedo was standard on all L98 cars and optional on LB9 (and possibly other) cars.
The actual RPO code for rear disc brakes is J65.
The site data confirms that assertion: https://www.thirdgen.org/1991-pontiac-firebird
I'm not sure but N10 may have been available on A4 equipped LB9 cars, but they got the smaller cam while the 5 speed cars got the L98's more aggressive cam. The cam may have made more of a difference than N10 (dual cat) exhaust setups did in terms of ratings.
Here is what okfoz posted in another thread
1987
Engine
Transmission
Speedometer
Tachometer
305 LG4 (4BBL)
A4, M5
85 mph
5000red / 6500max
305 LB9 (TPI)
A4
140 mph
5000red / 6500max
305 LB9 (TPI)
M5
140 mph
5500red / 8000max
350 L98 (B2L) (TPI)
A4
140 mph
5500red / 8000max
1988 & 1989
Engine
Transmission
Rear Gear
Speedometer
Tachometer
305 LO3 (TBI)
A4, M5
All
120 mph
5000red / 6500max
305 LB9 (TPI)
A4
2.73 (GU2)
120 mph
5000red / 6500max
305 LB9 (TPI)
M5
3.08 (GU4)
120 mph
5000red / 6500max
305 LB9 (TPI)
A4
3.23 (GU5)
3.27 (GW6)
140 mph
5000red / 6500max
305 LB9 (TPI)
M5
3.45 (GM3)
140 mph
5500red / 8000max
350 L98 (B2L)
A4
All
140 mph
5500red / 8000max
1990 - 1992
Engine
Transmission
Speedometer
Tachometer
305 LO3 (TBI)
A4, M5
120 mph
5000red / 6500max
305 LB9 (TPI)
A4, M5
120 mph
5000red / 6500max
305 LB9 (TPI)
M5
140 mph
5500red / 8000max
350 L98 (B2L) (TPI)
A4
140 mph
5500red / 8000max
Engine
Transmission
Speedometer
Tachometer
305 LG4 (4BBL)
A4, M5
85 mph
5000red / 6500max
305 LB9 (TPI)
A4
140 mph
5000red / 6500max
305 LB9 (TPI)
M5
140 mph
5500red / 8000max
350 L98 (B2L) (TPI)
A4
140 mph
5500red / 8000max
1988 & 1989
Engine
Transmission
Rear Gear
Speedometer
Tachometer
305 LO3 (TBI)
A4, M5
All
120 mph
5000red / 6500max
305 LB9 (TPI)
A4
2.73 (GU2)
120 mph
5000red / 6500max
305 LB9 (TPI)
M5
3.08 (GU4)
120 mph
5000red / 6500max
305 LB9 (TPI)
A4
3.23 (GU5)
3.27 (GW6)
140 mph
5000red / 6500max
305 LB9 (TPI)
M5
3.45 (GM3)
140 mph
5500red / 8000max
350 L98 (B2L)
A4
All
140 mph
5500red / 8000max
1990 - 1992
Engine
Transmission
Speedometer
Tachometer
305 LO3 (TBI)
A4, M5
120 mph
5000red / 6500max
305 LB9 (TPI)
A4, M5
120 mph
5000red / 6500max
305 LB9 (TPI)
M5
140 mph
5500red / 8000max
350 L98 (B2L) (TPI)
A4
140 mph
5500red / 8000max
You just need an image host such as Imageshack or Photobucket. Just get an account there, upload your photos and it generates the links to your images for posting in forums. Of the two I prefer Photobucket.
That makes sense then. Most of the cars I've seen that were made after 1987 didn't get the 140MPH speedo. Though my 1992 Formula was originally equipped with a 305TPI engine, 5 speed transmission and the 140MPH speedo. But again the A4 cars I've seen after 1987 generally didn't as I recall.
Brief instructions can be found here:
https://www.thirdgen.org/forums/prob...mages-tgo.html
Make sure to read the Important/Useful as well as Announcements as they contain important and frequently asked information.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
