Engine Color?!?!?!
Old Aug 21, 2010 | 03:32 PM
PT3BOOMER's Avatar
Car: 84 Z28 / 99 S-10 ZR2 4X4
Engine: STOCK CARB'D 305 WITH 350 HEADS
Axle/Gears: STOCK
Engine Color?!?!?!
I have an 84 z28 and my engine block,heads, intake and oil pan are blu......I'm going to replace it with a rebuilt 350....but people keep telling me that the color for chevy is "chevy orange" but blue happens to be my favorite color though......someone please steer me in the right direction....
Old Aug 21, 2010 | 03:57 PM
buffaloman's Avatar
Car: 1989 Firebird Fornula 350
Engine: 350 L98 / NOS
Transmission: 4sp Auto
Re: Engine Color?!?!?!
1982 Factory color was Chevy Blue.
They changed to Black in 1983.
So for the factory look the engine should be Black.
Put if you like Blue paint it Blue.
Old Aug 21, 2010 | 04:17 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
i think blue would be pretty cool.
Old Aug 21, 2010 | 04:22 PM
PT3BOOMER's Avatar
Axle/Gears: STOCK
Light blue or darker blue......and do I need the 2000F degree paint of 500F?
Old Aug 21, 2010 | 07:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
500 should be fine.
Paint it whatever color you want. Its your car.
my engine is silver
Old Aug 21, 2010 | 08:06 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
it is pretty much a matter of personal choice . myself i prefer a gray/silver color . people tell me , you will see every small oil leak & dirt it collects . call me stupid , but i want to know of any leaks no matter how small . just my thoughts , good luck .
Old Aug 23, 2010 | 10:24 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I painted an engine yellow... that was a mistake.. like Uncle Tom mentioned, everything shows...
John
Old Aug 24, 2010 | 07:20 AM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
I painted my old 305TPI block and heads pontiac baby blue. It always attracted the older croud at car shows. "Hey, you painted it the correct color for a poniac!" They'd always say to me. I thought it looked pretty cool too.
I'd say do it whatever color you want. Personally, I'm really not a huge chevy orange fan since everyones engine is chevy orange! I saw this engine paint color in lime green at the local parts store once. Always wanted to paint an engine that color haha.
Old Aug 24, 2010 | 07:26 AM
Convoy25's Avatar
yeah i think any color would be pretty sweet, and if its fast it'll make it even cooler.
though you dont want your engine bay to look like a crayon box
yellow engine, blue hoses, red wires, black air cleaner, aluminum intake, etc
Old Aug 24, 2010 | 03:34 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
For whatever reason, I'm a big fan of painting the block the stock color for that year vehicle. I painted the 350 I put into my IROC black, and the LSx that I'm building for it has been painted black too.
Old Aug 25, 2010 | 11:55 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Light Blue would be correct for '82...and I'd recommend the 2000F paint. An engine is not something you want to have to paint twice assuming you're doing it right, which is time consuming.
Old Aug 25, 2010 | 10:27 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
The really high temp paint tends to have a really dull finish. The 500F paint is just fine for an engine.
Old Aug 26, 2010 | 06:27 AM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Someone is going to ask, why did that paint the engine black? The price of not having to swap from one color to another and black engines run cooler than light color engines. I seen an article where they proved that and some people cannot comprehend the concept. Because they have always been told light colors are cooler. When you take a light source such as direct sunlight away the dark colors will let the heat escape ( under the hood ). Where as light colors and especially chrome will retain heat.
Old Aug 26, 2010 | 06:35 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That's true. If you're going to run your engine without coolant in space where thermal radiation is the only way to cool it, then black is great. Here on earth though, you can paint it any color you want as long as you're not going to loose sleep over the extra .001 degree in temperature you picked up by not painting it black.
Old Aug 26, 2010 | 07:39 AM
Jim85IROC's Avatar
Or compensate by just using one less coat. I'm willing to bet that the thickness of the paint has 10x more effect than the color.
Old Aug 26, 2010 | 09:26 AM
okfoz's Avatar
As from experieince, I used some 1200° Paint and it always came off my exhaust ports, but I got some higher 1500°F paint and it is still on there... I recommend the higher paint temp, from personal experience.
Old Aug 28, 2010 | 11:45 AM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
this.
my FORMULA is red so i painted it red and eventually to go with the cast look of the plenum and intake im going to put the vette magnesium valve covers on it. and when i do my 83, the car is med sand grey so i'll paint it some variation of puter or light charcoal.
otherwise i would paint them black. as for leaks, my motor has been in my car for the past 5 years and other than dust its clean with no oil visible. it shows leaks, its getting fixed.
i think i agree withJohn on the yellow, that and white are the only 2 colors i wouldnt use on an eng.
Old Sep 3, 2010 | 08:19 PM
okfoz's Avatar
I will admit however, until it got dirty, Yellow looked killer... then it was virtually impossible to clean and make look nice again.
john
Old Sep 3, 2010 | 09:55 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
john
the only way to keep it nice is to drive it little or not at all, thats no fun.
Old Sep 6, 2010 | 04:20 PM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Like said quite a few times, paint it what you want.
For those wondering what was blue and orange? It came from the 2nd gens. All 305's were light blue and 350's were orange. Since there wasn't any 350's in the third gens until 87 the early third gen V8s were blue until they started to paint all motors black. My 86 305 was black. Not sure on the years this started and ended but I do know that most 2nd gens were like this.
Old Sep 6, 2010 | 05:15 PM
Engine: that I like
No, that's incorrect. '76 was the last year for orange in any Chevy, whether it was a 350 or not.
Old Sep 6, 2010 | 05:20 PM
87 player bird's Avatar
Car: 87 player's trans am a4u (pepsi car
Engine: 305 tpi
Transmission: 5 speed
Axle/Gears: 3:42
So what would be the stock colour for an 87 ta? Someone p.m me this info please, as I'm going as close to factory as I can, Thanks in advance.
Old Sep 6, 2010 | 08:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Semi-gloss black
Old Sep 6, 2010 | 08:47 PM
Drew's Avatar
Up to 76 = Chevy orange
76-82 = Blue
83-up Black
Linson
Aug 21, 2015 02:12 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
87350gtanj
Aug 8, 2015 10:32 AM
