Correct Gas Cap for 1988 5.7 IROC....Vented or Non-Vented?
Old Mar 20, 2011 | 03:52 PM
Rumblin70SS's Avatar
Car: 88 IROC-Z T-Top car with Bose
Engine: L98 5.7
Axle/Gears: 9 Bolt with 3.27's
Hey guys,
I'm trying to determine what kind of gas cap my 1988 IROC is supposed to have. When I bought the car, it had a vented unit. When I looked up and purchased a Stant replacement, it was non-vented. If I use the vented cap, I smell gas fumes at the rear of the car. The non vented cap gives me fumes at the engine copmartment. Just trying to detemine the right cap so I can troubleshoot the fumes problem.
Thanks for the help!
Old Mar 20, 2011 | 04:54 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Correct Gas Cap for 1988 5.7 IROC....Vented or Non-Vented?
You will have a non-vented cap to contain evap emissions. You probably have a leaking hose on the system under the hood. Check near the evap canister.
Old Mar 21, 2011 | 11:44 AM
Engine: L98 5.7
Thanks for the info, I appreciate it! I did a 'sniff' test near the canister but was unable to come up with anything. I'll keep looking and hopefully I can find it.
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
kyleb24
Aug 15, 2015 08:24 AM
