rpo code D8F
Old Apr 10, 2011 | 10:42 AM
rob2000gt's Avatar
Car: 91 Trans Am GTA
Engine: Tpi 5.7
Axle/Gears: 3:23
rpo code D8F
What is this code D8F. I can only find it is a speed sensor but for what there was only 1,221 cars with this rpo code for 91.
Old Apr 10, 2011 | 08:59 PM
rob2000gt's Avatar
Engine: Tpi 5.7
Axle/Gears: 3:23
Re: rpo code D8F
I did a search and found that there was 3 options for speed sensors what replaced what what is the advantage of each what is better?
Old Apr 11, 2011 | 01:40 AM
Drew's Avatar
Re: rpo code D8F
There are a handful of D8* codes for different vehicle speed sensors. The only time it matters is when ordering a replacement VSS. The advantage of one over another is that one will work with you car, and the other probably won't.
Old Apr 11, 2011 | 11:27 PM
rob2000gt's Avatar
Engine: Tpi 5.7
Axle/Gears: 3:23
Re: rpo code D8F
why would they have multiple sensors for the same year same drivetrain doesnt make sense to me
Old Apr 12, 2011 | 11:54 AM
Drew's Avatar
Re: rpo code D8F
Does it really matter? The bottom line is that's how they did it. When you go to order a replacement VSS (even at the local auto parts store) the computer lists two or three options, each with about 3 RPO codes indicating which one it replaces. I've never seen a reason to look into it any further, when they go bad it's just easiest to order the right one and swap it out.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
