90 Iroc LB9 TPI factory rear drums
Old Apr 13, 2011 | 02:56 PM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
Came across a 90 Iroc LB9 TPI car with factory rear drums .
Its a posi 2.73 and its rpo is J41.
I was under the impression that Irocs with TPI other than convertibles or LO3 had 4 wheel discs.
I checked the rpo codes and sure enough its a factory 2.73 posi with drums T top car.
Is this one just an oddball or was the posi rear drums standard equipment and you had to upgrade from there........
Old Apr 13, 2011 | 03:01 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
Re: 90 Iroc LB9 TPI factory rear drums
no that sounds right for a 90.
Old Apr 13, 2011 | 04:46 PM
irock88's Avatar
Really ? Since 2004 Ive been through scrap yards and people selling parts off their Irocs and this is the first one Ive come across (other than rs ,lo3,convertible) that have rear drums all the others had rear disc brakes .
Old Apr 13, 2011 | 06:18 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello irock88!!
Sounds like you got the baby IROC!!
RPO PF2 = 15 inch IROC look a like wheels
115 MPH speedo!!
Mine is a 1989 set up the same way!!
Old Apr 15, 2011 | 01:28 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Nope, rear drums are pretty common...my 91 T/A LB9 has them as well.
IIRC there was even a shortage of rear discs at one point, so the factory had to put drums in a lot of cars that would have otherwise come with discs (such as WS6 cars), so they're even more common on the upper-level cars than they were originally planned to be.
Old Apr 15, 2011 | 02:59 PM
irock88's Avatar
Interesting I didnt know that, since all Irocs Ive come across had rear discs.
Just came across another but had aluminum rear drums,aluminum space saver tire and drive shaft ....it is a 89 tpi Iroc 5 speed
Old Apr 15, 2011 | 03:23 PM
Euro88Iroc's Avatar
Car: '88 white Iroc-Z
Mine is like that too. 1988 LB9, aluminum drums, space saver and driveshaft.
jaridjohn
Jul 8, 2024 03:49 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
