Project Budget Build
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Bout to start workin on my car restoration, try to do it kinda cheap and quick. Wanna get it done at least interior before the next local car show. Sail panels and visors are at the local upholstery shop. Picking them up Fri so i'll put pics up. Got a set of ABS plastic sail panels out of 91 Bird, did these come factory? And I'm usin my factory visors. So far 0$ into it and probably 20 to get recovered. Gonna try to redo and fix my headliner next week/weekend. So I'll have pics up soon
Car: 1989 Camaro RS
Engine: 305 TBI (5.0L)
Transmission: 4 speed automatic
Re: Project Budget Build
Good luck. I am about to start restoration on my 89 RS 305. We should keep in touch and help each other out.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
thanks u2 and sounds good. I wont be doing much to mine as i dont make alot of money and im still in school so i usually only get to on weekends.
Car: 1989 Camaro RS
Yea, I am kinda in the same boat. I work two part time jobs, and I will prolly only have about $200/ month to invest in my car. I am young and don't know alot about cars.
Car: 1986 Monte Carlo SS Aerocoupe
Engine: L69 305 H.O.
Transmission: 200-4R
love these kinda threads. i got one started as well. Just got my week or 2 ago and guy called this morning headliner, sail panels and visors are done and ready 2 pick up. $120... havent been able to work on it in a while but will update and post pics as i do
Car: 1989 Camaro RS
Yea, I just joined TGO like 3 days ago, have been reading ALOT of threads. I have a thread running now trying to get info on how to take apart the steering column. I need to fix the switch for the hazard lights. I wish I knew someone in my area that was an "expert" on third gens.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
if that, I got the help of a local uphoslstery shop plus i work at an autobody shop. But good luck. I worked on mine earlier Thread Starter
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
worked on my car for about 4 hours tried makin sail panel speaker boxes. Didnt go to well. Any suggestions on dimensions or size or help? Greatly needed and appreciated. Cant wait to get my sail panels and visors tomorrow
Will post pics
Will post pics Thread Starter
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Because of how open and how much space there is in that area and i wanna make an enclosure so maybe tighten up the bass and get more response out of the speaker. Recently did an experiment and sealed just the factory baffle up with duck tape and faded the speaker from left where i had it sealed and right where i didnt have it sealed and the left one sounded alot better. You could hear it alot better plus more bass output
Your best bet would be to ask on the audio forum, however I have never heard of anybody bothering. The speakers are designed to be open air, not in an enclosure like a subwoofer.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
i havent found anything and i kno that, I jus dont like it. I like to make things better but still look factory so maybe fiberglass around the whole baffle and then put it back in?
Car: 1989 Camaro RS
I wish I had a hook up like that. Eventually I will need Sail Panels, Visors, Headliner, and some other stuff.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Working on restoring my tail lights and making a custom set. This is all I have done so far. So far 5 dollars in for paint. Got silver metallic from walmart
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Well unfortunately cant rebuild headliner bc it was so crappy. Where is a cheap place to get a good plastic or fiberglass 1?
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
did some weatherstripping today and fixed the door striker. Both ideas came from here. Thanks everybody
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
I attempted to use some spray paint from lowes today to re paint my door handles and ttop trim. Turned out alright, but think imma jus wait till friday to buy some black base coat paint and use the paint gun and do all my black trim and make it look alot better. Hope to finish up soon and get her painted
cant wait
cant wait
I need the plastic "armrest thingys" in the rear to be black and mine are maroon. Does anyone know where to get replacements or should I just try to paint them?
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
sorry havent been doing much to the car lately no money. gotta put a set of tires and replace the windshield. Anyone else have problems keeping tires on their TA or Camaro?
