paper found under dash pad?
Old Oct 26, 2011 | 08:09 PM
gold_81_camaro's Avatar
Car: 1991 Camaro RS
Engine: TBI 305
Axle/Gears: 3.08
ok guys I was putting in my new 4x6 kenwoods yesterday and found a small slip of paper that says "1991 F-CAR IP TEST RESULTS AUG90 TIME 07/10 10:24 VIN # 149002 TESTER ID # 001 CHEVORLET MAN L03" and then has a big OK under it made of the letters O and K.
Anyone have a clue what this is and what exactly it means? Just curious thought it was a neat find in my car.
Old Oct 26, 2011 | 08:18 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: paper found under dash pad?
Instrument panel test passed/ ok and the car and person conducting the test.
I have found them in most of my cars. nifty
Old Oct 26, 2011 | 08:23 PM
Drew's Avatar
Does anyone ever use the search feature?
https://www.thirdgen.org/forums/hist...ant-label.html
https://www.thirdgen.org/forums/hist...hat-paper.html
https://www.thirdgen.org/forums/hist...ker-under.html
https://www.thirdgen.org/forums/hist...pid-sheet.html
Old Oct 30, 2011 | 06:52 AM
zee28's Avatar
Car: 86 iroc
yea some use the search feature and if it actually worked right more would.Type in something then spend 4 hours sorting through the stuff that has nothing to do with your search word.Thats why nobody uses it.
Old Oct 30, 2011 | 10:30 AM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
Completely agreed! The search feature is a joke when you want to find something relevant in under an hour, lol.
Old Oct 30, 2011 | 11:42 AM
Drew's Avatar
It works just fine, you just have to be smarter then the machine. You have to search for the unique term that is relevant to what you're after. Search "IP test" on this forum and you'll find 9 threads, how hard is it to read them? Usually you can find an answer faster then waiting for someone to reply to a thread.
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
z28_AJ
Aug 27, 2015 08:59 PM
Vintageracer
Aug 11, 2015 08:13 PM
