91 ws6 How rare?
Old Nov 17, 2011 | 03:06 PM
91camarolover's Avatar
Car: 91 RS, 84 Z28, 85 Iroc-z
Engine: 3.1L, 350 4 bolt, 350 TPI
Transmission: 700R4, 700R4, 700R4
Axle/Gears: 3.23, Unknown, Unknown posi
91 ws6 How rare?
How many ws6 Trans Ams were made in 91?
Old Nov 17, 2011 | 03:31 PM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
Re: 91 ws6 How rare?
On the home page you can go into "Firebird tech data"
Old Nov 17, 2011 | 03:54 PM
Yeah I couldn't find how many ws6's but I did check that first
Old Nov 17, 2011 | 04:50 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
WS6 started as a Ram Air model dreamt up by the marketing department in 1996, a long time after the last third gen rolled off the Van Nuys assembley plant floor. No doubt that the previous success of high buzz RPO codes such as Z28 and W30 were discussed in that meeting that approved the WS6 as a model.
Before that year, WS6 was an RPO code to ID suspension, and that's it. Similar to J65 brakes or CD4 pulse wipers. So there's no need to get too excited about the WS6 code on a third gen.
Old Nov 17, 2011 | 07:09 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Would this site be helpful?
http://ws6registry.com/
Old Nov 17, 2011 | 08:39 PM
Ok well the car I'm looking at has "WS6 Pontiac Performance Suspension" on the wheel caps. Is this anything special or just another nice looking low mile TA?
Old Nov 17, 2011 | 08:56 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Thats the same cap that came on my GTA. I sold the wheels and all to another guy so now his firebird will have them.
Old Nov 17, 2011 | 09:01 PM
Ok I was just curious because its a nice car and I saw that on the wheels. Heres the car if anybody's curious http://desmoines.craigslist.org/ctd/2701444453.html I guess my next question is: Is this a good price?
Old Nov 18, 2011 | 06:20 PM
RPO codes on my 91' WS6 are on the underside of the utility hatch/drivers side under the rear tire well. Need the RPO code to verify, anybody can slap on WS6 rims, with all do respect. I also have a "Performance suspension" badge where the glove box should be. Mine is not a TA, just a WS6. Performance suspension my butt! She takes corners great, but I hit a pebble and we are a dancin'. I even redid my whole front suspension (down to the control arm bushings and everything above) Didn't go cheap but didn't go over the top either. Should of spent more cash. WS6 = BRICK..........
Old Nov 18, 2011 | 10:41 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
So is it better to have a WS6 'Bird or a G92 Camaro? Didn't the G92 come w/ four wheels disc brakes, oil cooler, and a limited slip diff?
Old Nov 19, 2011 | 11:09 AM
AmorgetRS's Avatar
WS6 and G92 are not comparable. The Firebird RPO that matches best with G92 is R6P.
Old Nov 27, 2011 | 08:10 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
1) WS6 (from 1987 -1992) included 36mm front and 24mm rear sway bars, a quick ratio steering box, 16" wheels, 235-50 R-16 Tires, special springs and Gas filled shocks and struts.
2) 1985 & 1986 WS6 included rear disc brakes but it was not the case for 87-92.
3) many 91 & 92 Trans Am's had WS6 center caps and did not get WS6... Why? I have no ideas... may have been an error in the factory or a shifty dealer.
4) AmorgetRS is correct, the R6P would be a more similar option, Honestly the R6P was only a 91 & 92 only option. However the G92 was an option on the Trans Am from 1988-1992 and formula on 91 & 92. It triggered the 1LE package.
G92 included the performance gear ratio and some other performance enhancements. On the Firebird, the rear gear ratio was determined by the Engine, Transmission and trim level. The Formula and GTA all should have gotten the same equipment as a G92 Camaro when they were equipped with the LB9/M5 and the L98, however there is one example where it was not the case. The G92 was more or less the trigger for the 1LE on Firebirds.
John
Old Nov 27, 2011 | 08:48 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
So getting back to my original q, is it better to have a WS6 'Bird or a G92 Camaro, I'm still thinkin' the answer is a G92 Camaro.
Linson
Oct 24, 2025 02:00 PM
Ed1LE
Sep 30, 2018 09:14 AM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
jrdturbo
Mar 31, 2016 02:58 PM
sjorgens
Oct 1, 2015 07:54 PM
