87 TA Trans Rebuild/New
Engine: LS1, LB9, L03
Re: 87 TA Trans Rebuild/New
I'd figure between $1,000-3,000 for a quality rebuild. Pretty big spread I know, but really depends on who's doing the work, how much they're replacing, and what kind of warranty it will have when it's done.
COTM Editor (Retired)
Car: 89 Formula 350, TTA
DEFINITELY get a shift kit. get a TransGo - NOT a B&M.
i'm thinking 15-1600 for a quality rebuild with the shift kit.
123K on engine, trans I think was around 60K, (was pulled from a junkyard - hence why I had another problem
Guy redoing it thinks there is a possibility that the trans may be ok... Concentrating on getting it running right 1st.
was this before the car sat for 13 years? the reason i ask is because fuel that has gone bad, or other fuel delivery problems (bad fuel pump, for instance) can sometimes be mistaken for transmission slippage.
yeah sat after the 2nd/used trans went.
They are doing a major tune up, new carb , plugs, hoses , fluids etc. draining the tank new gas.
Engine started right up, no smoking....car wants to run.
said the body (underneath) is excellent. They haven't seen one in this condition. They like that I'm piecing it too vs saying yank everything out and re do x...y...z
some pics:
I know I could buy one for what I'm putting into it... thats not the point. It's my 1st car that I actually owned. more sentimental than anything else.
some pics:
engine runs well... (new carb & tune up), The flywheel is cracked... 150 alot for a fw?
flywheel will be installed w. the rebuild trans, everything installed for $1900 and change. Decent price?
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
