4 Wheel disk brakes vs 2 wheel disc brakes
Old Dec 11, 2011 | 10:06 PM
cerberus's Avatar
Car: 1985 IROC
Did all 85 IROCS come with 4 wheel disc brakes? I have a pic of a 85 IROC that doesnt have them.
Old Dec 11, 2011 | 10:32 PM
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
Re: 4 Wheel disk brakes vs 2 wheel disc brakes
Rear discs were an option... I've got an 88 with every option except Rear disc for some reason....
Old Dec 12, 2011 | 12:18 AM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Ive got an 88 with every possible option including rear disc brakes but no rear defrost if you can figure that one out!! Lol!
Old Dec 12, 2011 | 05:46 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
There was a shortage of the rear disc axles during production. Not sure exactly when it happened, but count yourselves blessed. Rear drums are a much better setup than those old cast iron rear calipers they used on 88's.
The 89-up aluminum rear caliper setup is o.k. though.
Old Dec 12, 2011 | 06:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Many people believe that if you have an IROC, it'll be equipped with discs all around, but that's simply not the case.
BTW, though the old-style Delco Moraine calipers have a tainted reputation on TGO, my personal experience with them was good. No issues. I think the key with them is to use the parking brake every time you park the car.
JamesC
Old Dec 12, 2011 | 01:15 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
I have the early rear discs on my IROC, I was cursing them the entire time i was changing the pads... "you mean I have to drop the LCA to get the caliper off??".... past that they seem to work pretty good. they were barely working when I got it but after I changed the pads I set and reset the park brake a bunch of times and use it religiously now they seem to work good. not sure if I'd trust only them holding the car though.
Old Dec 12, 2011 | 01:27 PM
cerberus's Avatar
Car: 1985 IROC
After reading about the mushy pedal and emergency brake usage mine are getting better now.
Old Dec 12, 2011 | 01:28 PM
Rumblin70SS's Avatar
Car: 88 IROC-Z T-Top car with Bose
Engine: L98 5.7
Axle/Gears: 9 Bolt with 3.27's
JamesC
What's the reasoning for using the parking brake? Adjustment?
Old Dec 12, 2011 | 01:32 PM
cerberus's Avatar
Car: 1985 IROC
The pads have adjusters on them, much like drum brakes do, that need to be activated with use, unfortunately GM thought everybody with Disc brakes uses a parking brake. So what happens is the pedal gets mushy and the rear pads dont work very well and stay unused.
My 85 with 30k still has original pads and the rear pads look like new.
Old Dec 12, 2011 | 01:56 PM
Engine: L98 5.7
That makes sense........I use my parking brake almost every time but I should replace the pads soon.
Nice car by the way!
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
overdriv
Aug 20, 2015 03:52 PM
novaderrik
Aug 10, 2015 12:44 PM
