Not Willing to Lose my Harrison A/C Compressor
My A/C system is in need of an overhaul, probably everything. I put it off over the last few years since I knew I wasn't going to be around to drive the car these last few years. Last time I had the car out in 2010 the compressor would engage and disengage every 5 seconds, like it was trying to compress but there was nothing in there to compress? Now I noticed it doesn't seem to engage at all.
I suspect that in addition to being converted to 134a and being overhauled in general, the compressor will probably need to be replaced. However, I don't want to lose the original compressor in the car.
Are there any recommended compressor rebuilders out there, or is that even possible? What have you guys done when your AC went out long after GM quit making the parts (I'm assuming the parts are not available from GM anymore)?
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Not Willing to Lose my Harrison A/C Compressor
IIRC,the outer sleeve of an R4 style compressor is
basicly held in place by o-rings and possibly a bend-over
tab when the compressor is not mounted-if old
compressor is bad and you cannot locate someone to
rebuild it,you could probably slip the outer sleeve off
the original compressor and install on the replacement
so that everything looks authentic-paint the cylinder
block of the replacement if needed and reuse your
original pulley and clutch
At a junkyard once i bought
an R4 compressor off a '95 S-10 to possibly use as
replacement if my original goes bad(thinking the'95
compressor might have improments over the original
somewhat troublesome 1976 design...)the '95
compressor,meant for R134 does have a different
hose fitting but i think my v-belt pulley and clutch
will fit.
At a junkyard once i boughtan R4 compressor off a '95 S-10 to possibly use as
will fit.
Car: 92 RS
Engine: L03 with Holley Sniper EFI, headers
Transmission: T-5, hurst billet shifter
Axle/Gears: 3.08 posi
$200 will get you a new one at Advance auto parts. Avoid rebuilt - anything I have got rebuilt always falls apart in the first year. Another $50 on ebay will get you about 3 cans of Freeze-12 which you can use as a replacement for R-12. Works great!
He's wanting to keep it stock appearing and as original as possible because he appreciates the originality of the car.
While not engaging is a bad sign, the fact it followed the 5 second engaging/disengaging stage makes it suspect that the system is simply too low on charge. The clutch on the compressor will not engage if the system is too low to prevent damage to the compressor. The compressor needs oil - which is part of the charge. There's a switch that's used in the system that controls this. The 5 second cycle is also an indication of possibly low charge.
Therefore, I wouldn't immediately suspect the compressor/clutch is bad, but it could simply be you've got slow leak to the point that it gone from a 5 second engage/disengage to a point there's not enough pressure/charge to close the pressure switch to engage the clutch on the compressor.
Do you know where the leak is? Is there oil around the compressor/clutch? If so, that will be bad news. How long as it stayed charged?
I'm sure Scott will chime in, as I believe he went through this issue himself of wanting to keep the system as original, or looking, as possible.
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
puma,
I had the 5 second cycle issue with my IROC when I first bought it...adding 1 lb of freon to it 2 years ago has yielded perfectly chilled AC ever since. I would recharge the system first...
Car: 82 Z28
Transmission: BW T-10
As far as the compressor goes, try a local rebuilder- I was faced with the same thing on my '82, 82s have a cool pink sticker on the compressor that says "DelcoAir" I called the rebuilder, and asked them to rebuild my compressor without painting it or harming the sticker, they did a great job, my rebuilt compressor looks and works like new, pink sticker and all!
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
I've got my old compressor with 120k miles, if you need it let me know, $105 shipped.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Your compressor might still be ok. But if not, there's nothing wrong with a quality rebuilt unit. In fact putting new guts into the orininal case might be better than a cheap new Chinese one.
Get yourself some R12 and charge it up a bit. It will probably be good as new. You can find people selling R12 cans on Craigslist. Regardless of what you have heard, R134A will NOT work as well to cool your car. Jump out the low pressure switch to make sure the compressor is good. More then likely the compressor is fine. If you feel the need to change hoses, I would still find a few cans of R12 to recharge it. Pull a vacuum before you charge it to get all the moisture out.
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
I'd like to keep my Harrison also, So can anyone suggest a rebuilder? (name, contact info) or a kit to rebuild one? Thanks.
Ok, I'm chiming in. I replaced my AC system last year as my belt was dancing all over the place. I was told that the belt was dancing because the bearings were going. Another way to know the bearings were going was the oil spray on the hood liner. Finally, the compressor let go and made a nasty roar when it was on. I replaced the compressor, orifice tube and dryer. I had R12 put in. Everybody I spoke to said that the original R4 compressor was junk. Any original replacement is junk! All rebuilt R4s are junk! I bought a new R4 compressor.
I went to my local AC Delco shop and asked what the replacement part number was for my car and was given multiple part numbers. One was a replacement part number for the Harrison and another was a generic replacement for the same car. I went with the 1st option and it was an almost perfect match. I peeled off the new sticker on the compressor and carefully peeled the Harrison sticker off. I used a heat gun and a razor blade and slowly peeled up the Harrison sticker. Heating it up allowed the glue to loosen up and the aluminum sticker separated from the glue leaving a perfectly clean aluminum Harrison sticker. I then purchased some 3M doubles sided tape (uber thin) and carefully laid the Harrison sticker on it. I started at one end and rolled the Harrison sticker onto the tape to eliminate any bubbles. I then trimmed the rest of the tape from the edges of the Harrison sticker, peeled the paper from the other side of the 3M tape and applied it to the exact spot the old one sat. You can't tell the difference!! Here is my sticker after I removed it. Even being careful, it looks like it's stretched in a few places, but it laid nice and flat when applied to the 3M tape. The razor blade was used to get up one corner enough to grip with my fingers and carefully pull it back. You can see the damage I did to the top right corner. That's the only imperfection.
I'll try to get a pic tomorrow so you can see how perfect it looks now.
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
My car still has the Harrison compressor, but it's cracked at the edge of the casing (seam). I had it charged, and it all leaked out within an hour. I hear this is a common problem, it's a shame there's no way to seal that crack back up.
Transmission: World Class T-5
Axle/Gears: BW 3.45
All three of my Camaros spray compressor oil on the hood liner. My '89 has done it, literally, ever since I can remember.
Car: '82 z28
Engine: L83 5.7
that oil leakage is because R4 compressors generate
fine aluminum dust as they operate and this mixes with
the oil to collect and ball up on the shaft seal face and
cause the leak-can be taken apart and cleaned...
The new replacement I bought from GM parts direct was a perfect match and I simply had a local sign shop create me an identical replacement sticker/decal. No biggie.
Ok, here's my new compressor and old sticker replaced. The only difference in my factory compressor and this one is the bare aluminum areas. The factory was completely black. I figured nobody would notice. Okfoz saw the car a couple weeks ago and the first words outta his mouth when looking under the hood was, "That's not the factory compressor, is it?"
Thanks for those pics, looks good.
This is definitely on the list of seemingly endless things to take care of to get the car back on the road reliably after sitting so long, though I've got some other priorities to take care of first but hopefully I can get it taken care of sometime this season.
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I have one with 65k miles on it in my basement. Make me an offer and its yours. Feels smooth and looks pretty good too. Should clean up nice.
Car: camaro lt 1976
Engine: 8cly, 305
Transmission: auto 350
Axle/Gears: standard for camaro
Car: 1991 Camaro B4C
I ended up going the route scottmoyer went with the replacement. I have yet to transfer the sticker, though; the replacement has one that is actually quite close to the original. The one downside is on the 91 TPI, the compressor is on the passenger side so the silver face is exposed and more obvious. Most people would never know, but we do. I kept the original compressor.
It is nice to have working AC again, though. Did a full R134 conversion and I actually had to turn the AC down to low despite sitting in stop and go traffic at close to 100 degree weather.
2012sergen11
Oct 13, 2015 07:38 PM
