battery question
Old Apr 22, 2012 | 11:53 AM
mans1's Avatar
Car: pontiac firebird trans am 1984
Engine: 5.0 v8 H.O
Transmission: auto
Axle/Gears: 700R4 auto overdrive
battery question
hi what is the proper battery for a 5.0 H.O engine as i have been told many things and all the batterys i get what they say lasts about a few months and packs in if you help me to get the proper battery or with the same output Cheers
Old Apr 22, 2012 | 12:01 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: battery question
Group 75. Any CCA will work, but buy the best one you can afford. If they aren't lasting long, check to make sure you are charging. If yes, also check if soemthing on the car is drawing power while it's parked.
Old Apr 22, 2012 | 12:14 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I'm not sure if your car calls for a 108 amp generator or not,but make sure you have the right one.If you have one that's to small,your drawing more power out of your battery that needs to.And check to see what eseibel67 is suggesting.
Old Apr 29, 2012 | 07:13 AM
mans1's Avatar
Engine: 5.0 v8 H.O
Transmission: auto
hi the battery does it even when off the car when put it back on a day later same result battery flat thanks
Old Apr 29, 2012 | 07:43 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
You need a new battery.
Old Apr 29, 2012 | 10:11 AM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
I always try to get the one with the highest cracking amp usually a 750. I would definately check for a drain on the battery when parked with a voltmeter
Old Apr 29, 2012 | 05:13 PM
two-if-by-sea's Avatar
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
Can you go into a little detail about this? If the alternator is too small, I assume the result will ultimately be a dead battery? Is there a such thing as "too big"? I have RPO K60, which I believe is a 100 amp alternator. If I go larger, will I fry anything?
Old Apr 29, 2012 | 07:22 PM
mantaguy's Avatar
Engine: 5.0 EFI
You can go to 108 amp,but a 100 should do a sufficient job.the question is,is your alternator one of the two,I've seen people buy some out of junk yards and just old plain used ones.But this may not be your problem,you said you battery doesn't hold a charge so that's a bad battery or their is something drawing power down when your car is off.You have to check each one,take your alternator and battery to a Advance Auto store or similar ,they will check it for FREE,then you go from their.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
redmaroz
Aug 16, 2015 11:40 PM
